Compare 2 dates
First of all, all my apologies for my english speaking.
I have a question for you guys, please help.
I’m monitoring a batch : I have 2 timestamp (when the batch starts and when it ends).
I would like to get the differente between the two to see how the batch lasted.
Can you help me please ?
Thank you very much
you could use a processing pipeline rule like:
rule "calc_processing_time"
  // REQUESTTIME Format hh:mi:ss.mmm
  has_field("REQUESTTIME") AND
  // RESPONSETIME Format hh:mi:ss.mmm
  has_field("RESPONSETIME")
    // the math of RESPONSETIME minus REQUESTTIME
    // translated to milliseconds
    set_field( "processing_time", parse_date(
    				value: to_string($message.RESPONSETIME),
    				pattern: "HH:mm:ss.SSS",
    				locale:"en" ).millis - parse_date(
    						value: to_string($message.REQUESTTIME),
    						locale:"en" ).millis );
The above is not tested, but should work with a little adjustments.
