I would like to get the time difference of two timestamps having "started" and "finished", they share the same correlationid
I would like to get the time difference of two timestamps having “started” and “finished”, they share the same correlationid
  • OS Information:Linux
  • Package Version: 3.3.15
  • epoch timestamp
I tried to use pipeline rules to get epoch format, below is the code snippet:
rule “Date”
has_field(“message”)
let new_date = parse_unix_milliseconds(to_string($message.timestamp)*1000,“YYYY-MM-DDTHH:mm:ss.sssZ”);
set_field(“epoch_timestamp”, new_date);
  • calculate the time difference from query
I tried to use pipe and “eval” in the query, below is the code snippet:
[correlationid=“my-correlationid”]
| eval started = parse_datetime(“started”, “YYYY-MM-DDTHH:mm:ss.sssZ”)
| eval finished = parse_datetime(“finished”, “YYYY-MM-DDTHH:mm:ss.sssZ”)
| eval time_diff = finished - started
neither worked so far. any suggestions?
Thank you!
Tony
Hey @ztony
Sorry for the delay,
you looking for measurement of log latency? If so something like this example?
rule "add pipeline_processingtime"
    has_field("input_time")
    let ingestion_time = to_date($message.input_time).millis;
    let current_time = to_date(now()).millis;
    let millis_diff = to_long(to_long(current_time) - to_long(ingestion_time));
    set_field("pipeline_processingtime", millis_diff);
