In a message having two date fields. One is start_time and other is end time. Need to calculate difference of these two times in minutes or seconds in pipeline processing. Please help to fix this.
rule “Timestamp”
true
let first_time = flex_parse_date(to_string($message.first_occur_time))); //yyyy-MM-dd HH:mm:ss
let last_time = flex_parse_date(to_string($message.last_occur_time)); //yyyy-MM-dd HH:mm:ss
let ts_start_seconds = seconds(to_long(first_time));
let ts_end_seconds = seconds(to_long(last_time));
set_field(“total_time_taken”, ts_end_seconds-ts_start_seconds);
you might want to adopt the rule from the following:
rule "calc_processing_time"
// REQUESTTIME Format hh:mi:ss.mmm
has_field("REQUESTTIME") AND
// RESPONSETIME Format hh:mi:ss.mmm
has_field("RESPONSETIME")
// the math of RESPONSETIME minus REQUESTTIME
// translated to milliseconds
set_field( "processing_time", parse_date(
value: to_string($message.RESPONSETIME),
pattern: "HH:mm:ss.SSS",
locale:"en" ).millis - parse_date(
value: to_string($message.REQUESTTIME),
locale:"en" ).millis );
