Is it possible to install the graylog collector sidecar in a choosen directory ? Especially with the command line in silent mode.
Because I would like to install it silently in D:\Appli\Graylog\ instead of the default C:\Program Files\Graylog.
with the installer that’s currently not possible. But as you have to deploy your own configuration files anyway (all paths need to reflect the change), you can also take the Windows binary from the tar.gz file and make a custom installation out of it.
Thanks for the answer.
I have also found a feature request on gitbuh:
https://github.com/Graylog2/collector-sidecar/issues/176
