Change graylog level 1,2,3 to info, error etc in graylog 3.0.2
Hi team,
I am using logstash which sends logs to graylog but somehow logs level are converted into numbers, i want to show them as it is. currently, the log level is converted automatically. there any way I can stop this conversion? please help
best regards,
Rajnish
log level is a number, so you see it as it is…
Check prival in syslog.
With decorator, you can see the strings.
