Change default index config
Hello, i have a question.
Can i change default index config?
What the case:
I use graylog in docker with es cluster. And i need so that after up graylog all default index have next parametr:
  • Shards: 1
  • Replicas: 2
It’s possible?
Thank you.
he @MalinkinSA
yes that is possible - System > Indices > Default index, read the docs about index sets to get more information.
https://docs.graylog.org/en/3.2/pages/streams.html#index-sets
Hello, @jan.
I apologize, now i see mistake in my question.
About editing indexes parameters via gui i knew.
I want asked about next: can i specify my own setting for all indexes (default and all new created)? e.g. I launch my docker image and Default index set and all new index be with non default values? Or i must do it via GUI after install?
he @MalinkinSA
you could use the API to make those settings or change the parameters before the first startup in the configuration. but the second option will be disappear - so changing that by using the API is fare better.
