I’m trying to set the elasticsearch index name in graylog configuration file. But its not reflected after the initialisation. Still its creating index as “graylog_0” in elasticsearch.
Should I need to make changes in somewhere else ?.
Thanks, Now I can create my own index in elsaticsearch.
But unable to delete the default index as “streams was assigned to default index” . I tried to change the default streams to newly created one. But couldn’t find an option to changes the default streams.
I could change the default index set to newly created.
