Can't delete test input in system/input
I can’t delete a created input from web interface using admin user, but get an error of user permissions
The permissions check for the following request failed,
while trying to access /system/inputs.
There was an error fetching a resource: Access Denied. Additional information: <HTML>
<HEAD>
<TITLE>Access Denied</TITLE>
</HEAD>
<BODY BGCOLOR="white" FGCOLOR="black">
<H1>Access Denied</H1>
<HR>
<FONT FACE="Helvetica,Arial"><B>
Description: You are not allowed to access the document you requested.
</B></FONT>
<HR>
</BODY>
  • OS Information:
    Debian GNU/Linux 12 (bookworm)
  • Package Version:
    graylog-server/stable,now 5.1.7-1 amd64
    opensearch/stable,now 2.11.0 amd64 [installed]
    mongodb-org/bullseye,now 6.0.11 amd64 [installed]
    apache2/stable,now 2.4.57-2 amd64 [installed]
/etc/graylog/server/server.conf
is_leader = true
root_username = admin
http_enable_gzip = true
http_max_header_size = 8192
http_thread_pool_size = 64
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_size = 5gb
mongodb_uri = mongodb://graylog:graylog@localhost/graylog
/etc/opensearch/opensearch.yml
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /var/lib/opensearch
discovery.type: single-node
plugins.security.ssl.transport.pemcert_filepath: esnode.pem
plugins.security.ssl.transport.pemkey_filepath: esnode-key.pem
plugins.security.ssl.transport.pemtrustedcas_filepath: root-ca.pem
plugins.security.ssl.transport.enforce_hostname_verification: false
plugins.security.ssl.http.enabled: true
plugins.security.ssl.http.pemcert_filepath: esnode.pem
plugins.security.ssl.http.pemkey_filepath: esnode-key.pem
plugins.security.ssl.http.pemtrustedcas_filepath: root-ca.pem
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
plugins.security.authcz.admin_dn:
  - CN=kirk,OU=client,O=client,L=test, C=de
plugins.security.audit.type: internal_opensearch
plugins.security.enable_snapshot_restore_privilege: true
plugins.security.check_snapshot_restore_write_privileges: true
plugins.security.restapi.roles_enabled: ["all_access", "security_rest_api_access"]
plugins.security.system_indices.enabled: true
plugins.security.system_indices.indices: [".plugins-ml-config", ".plugins-ml-connector", ".plugins-ml-model-group", ".plugins-ml-model", ".plugins-ml-task", ".plugins-ml-conversation-meta", ".plugins-ml-conversation-interactions", ".opendistro-alerting-config", ".opendistro-alerting-alert*", ".opendistro-anomaly-results*", ".opendistro-anomaly-detector*", ".opendistro-anomaly-checkpoints", ".opendistro-anomaly-detection-state", ".opendistro-reports-*", ".opensearch-notifications-*", ".opensearch-notebooks", ".opensearch-observability", ".ql-datasources", ".opendistro-asynchronous-search-response*", ".replication-metadata-store", ".opensearch-knn-models", ".geospatial-ip2geo-data*"]
node.max_local_storage_nodes: 3
/etc/mongod.conf
storage:
  dbPath: /var/lib/mongodb
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
net:
  port: 27017
  bindIp: 127.0.0.1
processManagement:
  timeZoneInfo: /usr/share/zoneinfo
/etc/opensearch/jvm.options
-Xms8g
-Xmx8g
8-10:-XX:+UseConcMarkSweepGC
8-10:-XX:CMSInitiatingOccupancyFraction=75
8-10:-XX:+UseCMSInitiatingOccupancyOnly
11-:-XX:+UseG1GC
11-:-XX:G1ReservePercent=25
11-:-XX:InitiatingHeapOccupancyPercent=30
-Djava.io.tmpdir=${OPENSEARCH_TMPDIR}
-XX:+HeapDumpOnOutOfMemoryError
-XX:HeapDumpPath=/var/lib/opensearch
-XX:ErrorFile=/var/log/opensearch/hs_err_pid%p.log
8:-XX:+PrintGCDetails
8:-XX:+PrintGCDateStamps
8:-XX:+PrintTenuringDistribution
8:-XX:+PrintGCApplicationStoppedTime
8:-Xloggc:/var/log/opensearch/gc.log
8:-XX:+UseGCLogFileRotation
8:-XX:NumberOfGCLogFiles=32
8:-XX:GCLogFileSize=64m
9-:-Xlog:gc*,gc+age=trace,safepoint:file=/var/log/opensearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m
18-:-Djava.security.manager=allow
20:--add-modules=jdk.incubator.vector
-Djava.util.concurrent.ForkJoinPool.common.threadFactory=org.opensearch.secure_sm.SecuredForkJoinWorkerThreadFactory
-Dclk.tck=100
-Djdk.attach.allowAttachSelf=true
-Djava.security.policy=file:///etc/opensearch/opensearch-performance-analyzer/opensearch_security.policy
--add-opens=jdk.attach/sun.tools.attach=ALL-UNNAMED
from access and error log of apache i got no particular info
Ive tried to investigate on apache, mongodb, opensearch and graylog logs but i cant figure out what i can try to do
How can i delete the input?
Thank you all
How many graylog nodes do you have, is it just the one?
Can you try to delete via the api browser? /api/api-browser/
And if that fails can you post the response text? Can you check your server.log to see if there are any errors?
Yes, i have just one graylog node
I get on api browser from /api/api-browser/global/index.html because from /api/api-browser i get a login page where i cant login
This is the error if i try to delete from api browser
Response Body
Access Denied
Response Code
403
Response Headers
{"Cache-Control":"no-store","Connection":"keep-alive","Content-Language":"en","Content-Length":"249","Content-Type":"text/html","Date":"Fri, 27 Oct 2023 09:40:24 GMT"}
i found no errors on server.log
Can you try to login to your graylog cluster with your admin account and then navigate to the API browser page? It will reuse the same user session.
Yes, i log in on the cluster (http://graylogIP/) with admin account, then i go to System, then Nodes, then Cluster Global Api Browser and i get to te API browser page. From there i try to delete the input and then get the error
Update: i get this error also when i try to delete streams and inputs, but i can create them with no problem
UPDATE
I finally solved the problem by deactivating from the Internet settings of my client the use of an http proxy. Although it was explicit among the options not to use the proxy for local addresses, once it was disabled I was able to complete all operations
Thnak you
