Description of your problem
When attempting to modify anything in the Graylog GUI, I receive a 405 error. ie. if I try to delete an input it will say:
“Deleting input “test” failed with status: Error: cannot DELETE https://…(405)”
If I try to update my default index settings, I get a:
“Updating index set ‘Default index set’ failed with status: cannot PUT https://… (405)”
Basically anything I try to modify receives this error. However, I’m able to add new items such as a new input without any issues. I just can’t delete it afterwards.
I’m logged in as admin so I should have full privileges. I recently AD integrated my Graylog server a few weeks ago and things appeared to be working after that.
Anyone have any ideas?
Environmental information
Graylog 4.0.9 running on RHEL7.9. selinux enabled
Operating system information
RHEL7.9 x86_64
Package versions
- Graylog - 4.0.9
- MongoDB - 4.0.25
- Elasticsearch - 7.13.3
When I receive these errors I see the 405 errors in the apache logs, but nothing in the graylog logs.
