Blank page when accessing graylog
Suddenly we have blank page during accessing graylog.
The previous issue has been solved on here
But now the indication seems different. I found below log,
2022-09-21T17:44:55.674+08:00 INFO [AbstractIndexCountBasedRetentionStrategy] Running retention strategy [org.graylog.plugins.archive.indexer.retention.strategies.ArchiveRetentionStrategy] for indices <graylog_3, graylog_4>
2022-09-21T17:44:55.677+08:00 INFO [SystemJobManager] Submitted SystemJob <0c8a92d0-3992-11ed-bdb6-000c2969c5d6> [org.graylog.plugins.archive.job.ArchiveCreateSystemJob]
2022-09-21T17:44:55.677+08:00 ERROR [ArchiveCreateJob] Unable to archive indices <graylog_3, graylog_4> because there is no valid license.
2022-09-21T17:44:55.677+08:00 INFO [SystemJobManager] SystemJob <0c8a92d0-3992-11ed-bdb6-000c2969c5d6> [org.graylog.plugins.archive.job.ArchiveCreateSystemJob] finished in 0ms.
It mentioning “…no valid license”.
For your information, I use enterprise license for the graylog.
  • OS Information:
    DISTRIB_ID=Ubuntu
    DISTRIB_RELEASE=18.04
    DISTRIB_CODENAME=bionic
    DISTRIB_DESCRIPTION=“Ubuntu 18.04.6 LTS”
  • Package Version:
    graylog-4.0-repository/now 1-2 all [installed,local]
    graylog-enterprise/stable,now 4.2.7-1 all [installed,upgradable to: 4.2.13-1]
Please advise how to solve this issue. Thank you.
Best regards,
Subhan
Looks like an issue with a plugin you are using or the data coming to a plugin? do you have anything other than a default install?
Hello @tmacgbay ,
Thank you for your response. below the plugin list on the server,
I would pull out the telegram-alert plugin and restart Graylog - there may be compatibility issues with it…
Hello @tmacgbay
Thank you for your advise.
But we use the telegram alert on this graylog. Once it deleted, the features will not working yes?
Best regards,
Ahmad Subhan Fajri
It could be a setting that is having an issue. Take it out temporarily and see if that fixes your issue, we can work from there.
-Tad
