Aggregation of an Aggregation
I would like to create an Aggregation based on another Aggregation, so a nested Aggregation if you will.
I have created an aggregation showing the latest status of a ticket (specifically alerts from O365):
I would like to then create a further Aggregation based on this (showing a pi-chart of current statuses), by grouping by the Latest(o365_alert_status) field and using the count metric.
Can I create either a nested Aggregation, an Aggregation based on this Aggregation or can I create a metric, based on another metric (or any other solution)?
  • Package Version: Graylog 4.3.8+8c4705e on graylog (Private Build 1.8.0_342 on Linux 5.15.0-48-generic)
Does anyone have any advice on how (or if) this is achievable?
Hello @3bCarl && Welcome
I have not created a widget for a “Aggregation based on another Aggregation”. Sound good thou.
As for…
I gave this a try and was unable to create a PIE chart with Latest Value. Here was the test I execute.
Trying to mimic your widget lay out but I had to use different fields.
Test#1
Based off your explanation, unfortunately the pie chart did not work with Latest Value, so I had this configuration.
or
Not sure if you seen this document.
I think this maybe something your looking for.
That’s about all I have for ya, I know it not what your looking for but maybe someone else here has done that.
Not sure if this would help, but using Cardinality in a bar chart?
Thanks @gsmith.
Yes, the pi chart won’t show anything in my example as I can’t convert the results of the metrics (latest value in my example) into a numeric count (likely using cardinality as you have suggested). I’m currently using the above data table as a work around and sorting by status to see what’s open or new.
Alas, it seems it’s not currently possible to use cardinality on the latest value (or use a metric of a metric).
Thanks for the pointers.
