My labs is not connected to Internet so the World Map plugin does not work, the map cannot load.
Is there a way to make this work totally offline ?
Can I download the map locally in Graylog ?
The Map widget can currently not be used offline.
FWIW, only the web browser of the user needs an Internet connection to communicate with the OSM tile server.
Thank you.
So I can’t use this plugin as my browser is not connected to Internet.
