Error src_ip_geolocation
World Map
Loading map information failed: cannot POST http://172.18.146.19:9000/api/plugins/org.graylog.plugins.map/mapdata (500)
What did you try to say? What did you tried to resolve? What is the question you have?
When I enable the MAP option to locate an IP address, the system throws in that it can not load the plugs
hast your Graylog Server the option to connect to the internet to retrieve the information?
