WinLogBeat Help
I’m sending Windows event logs to Graylog using Sidecar and Winlogbeat. There are some repetitive events that I’d like to drop and not send at all to Graylog. The problem is I can’t find a combination that works in the Winlogbeat config file that will drop the events. I’ve searched and searched and have found many combinations, but nothing actually drops the event.
  • OS Information: RHEL 9.6
  • Package Version: 6.3.2
Here is the XML from the event I’m trying to drop. Note, I don’t want to always drop event 3004, I just want to drop event 3004 when either the message or FileNameBuffer contain ScriptControl64_19907.dll.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Microsoft-Windows-CodeIntegrity" Guid="{4ee76bd8-3cf4-44a0-a0ac-3937643e37a3}" />
  <EventID>3004</EventID>
  <Version>1</Version>
  <Level>2</Level>
  <Task>1</Task>
  <Opcode>104</Opcode>
  <Keywords>0x8000000000000000</Keywords>
  <TimeCreated SystemTime="2025-08-25T12:40:27.0776467Z" />
  <EventRecordID>170406</EventRecordID>
  <Correlation ActivityID="{561ea484-0abb-0004-7c87-c159bb0adc01}" />
  <Execution ProcessID="9060" ThreadID="44596" />
  <Channel>Microsoft-Windows-CodeIntegrity/Operational</Channel>
  <Computer>ComputerName</Computer>
  <Security UserID="S-1-5-20" />
  </System>
- <EventData>
  <Data Name="FileNameLength">66</Data>
  <Data Name="FileNameBuffer">\Device\HarddiskVolume4\Windows\System32\ScriptControl64_19907.dll</Data>
  <Data Name="SecureRequired">0x80000000</Data>
  <Data Name="RequestedSigningLevel">12</Data>
  <Data Name="ProcessNameLength">52</Data>
  <Data Name="ProcessNameBuffer">\Device\HarddiskVolume4\Windows\System32\svchost.exe</Data>
  </EventData>
  </Event>
Here is the config I’m currently trying that does not work.
output.logstash:
   hosts: ["graylog.fqdn:5044"]
path:
  data: C:\Program Files\Graylog\sidecar\generated\689364b29491b03703d458c8\data
  logs: C:\Program Files\Graylog\sidecar\generated\689364b29491b03703d458c8\logs
logging:
  level: debug
  to_files: true
  files:
    path: C:\temp
tags:
 - windows
winlogbeat:
  event_logs:
  - name: Application
    ignore_older: 24h
  - name: System
    ignore_older: 24h
    level: critical, error, warning
  - name: Security
    ignore_older: 24h
    level: information
  - name: Microsoft-Windows-LAPS/Operational
    ignore_older: 24h
    event_id: 10018, 10029, 10020, 10031, 10041, 10043, 10044
  - name: Microsoft-Windows-CodeIntegrity/Operational
    ignore_older: 24h
  processors:
    - drop_event.when.and:
        - equals.winlog.event_id: 3004
        - regexp.winlog.event_data.FileNameBuffer: '\bScriptControl64_19907\.dll\b'
I need some help sending me in the correct direction to be able to drop events using Winlogbeat.
Here are some of the posts I’ve used.
Winlogbeat drop event not working for specific fields - Graylog Central (peer support) - Graylog Community
Logstash-conf/winlogbeat_example.yml at master · langitio/Logstash-conf · GitHub
Drop events | Winlogbeat Reference [8.9] | Elastic
Thank you!
Jim
