Winlogbeat drop event not working for specific fields
I want to monitor File/folder activities on the computers and servers.
And I want to drop on the client side all useless/not needed events.
As monitoring files activites generate a big amount of logs, can overload the network if thousand of clients and fill the disk space in short time, this is a very important part.
My Sidecar conf for this objective:
- name: Security
     event_id: 4656, 4663, 4670, 4907
     ignore_older: 24h
     tags: [filesystem]
     processors:
       - script:
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\security\config\winlogbeat-security.js
       - drop_event.when.not.and:
            - equals.winlog.event_data.ObjectType: "File"
       - drop_event.when.or:
            - equals.winlog.event_data.winlog_task: "Authorization Policy Change"
            - equals.winlog.event_data.winlog_task: "Registry"
            - equals.winlog.event_data.winlog_task: "Kernel Object"
            - equals.winlog.event_data.SubjectUserSid: 'S-1-5-18'
            - equals.winlog.event_data.SubjectUserSid: 'S-1-5-19'
            - equals.winlog.event_data.AccessList: '%%1538'
            - equals.winlog.event_data.AccessList: '%%1539'
            - equals.winlog.event_data.AccessList: '%%1541'
            - equals.winlog.event_data.AccessList: '%%1542'
            - equals.winlog.event_data.AccessList: '%%4416'
            - equals.winlog.event_data.AccessList: '%%4419'
            - equals.winlog.event_data.AccessList: '%%4420'
            - equals.winlog.event_data.AccessList: '%%4423'
            - equals.winlog.event_data.AccessList: '%%4424'
On graylod side, I can identify for explorer.exe process and powershell/cmd
  • File deletion
  • File creation
  • Changing/Write Owner
  • Cut/Past or Move from/to
All the - equals.winlog.event_data.AccessList does not work and the event are still sent to the Graylog server.
Theses drop statement are working:
Theses are not working:
  • OS Information:
Graylog 5.2.1
Opensearch 2.11.0
mongo 6.0.11
sidecar 1.5.0
winlogbeat 7.17.13.0
I tried the double quote, it not works either.
I double check the log format from Windows side and it correspond to my dropt event condition:
Is my syntax wrong ?
I found the solution by myself, which is using regexp instead of equals
           - regexp.winlog.event_data.AccessList: '^%%4416.*'
           - regexp.winlog.event_data.AccessList: '^%%1538.*'
           - regexp.winlog.event_data.AccessList: '^%%1539.*'
           - regexp.winlog.event_data.AccessList: '^%%1541.*'
           - regexp.winlog.event_data.AccessList: '^%%1542.*'
           - regexp.winlog.event_data.AccessList: '^%%4419.*'
           - regexp.winlog.event_data.AccessList: '^%%4420.*'
           - regexp.winlog.event_data.AccessList: '^%%4421.*'
           - regexp.winlog.event_data.AccessList: '^%%4423.*'
           - regexp.winlog.event_data.AccessList: '^%%4424.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._-]+\\AppData\\Local\\Microsoft\\Windows\\INetCache\\IE.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\Users\\[a-zA-Z0-9._-]+\\AppData\\Roaming\\Microsoft\\Windows\Recent.*'
           - regexp.winlog.event_data.ObjectName: '^(?i)C\:\\\$Recycle.Bin.*'
If it can help someone someday :+1:
