Why I need to set 0.0.0.0 bind address for géolocalisation?
Everything is in the title.
I try this tuto, but i don’t understand why I need to set 0.0.0.0 for the bind address, I always set my local ip 127.0.0.1.
http://docs.graylog.org/en/2.5/pages/geolocation.html
Thank you !
The image in the tutorial shows an input definition, a receiver for logging data. Why would you ever run that on 127.0.0.1? That would mean it would only receive input from the Graylog host itself. This particular input (plain-tcp) is defined only to test the geo-lo configuration
Which part are you referring to?
