Hello everyone.
With rename of master to leader https://github.com/Graylog2/graylog2-server/pull/11766 talks about something they call leader election.
Anyone knows what that is? Can graylog cluster choose its leader automatically now?
Hello everyone.
I have always though that I must force exactly one node to be this leader/master via is_master = true per
# If you are running more than one instances of Graylog server you have to select one of these
# instances as leader. The leader will perform some periodical tasks that non-leaders won't perform.
is_leader = true
Hello @nisow95612
TBH Iām not sure why it went from master ā Leader. Perhaps āmasterā offended someone but Iām not sure.
Iām running one node Graylog 4.3.5+32fa802 and never reconfigured my GL configuration file to leader. I donāt see any issue.
EDIT: yeah man, I just read over all the documents, not sure what the difference really is. It seams be act just like the configuration is_master.
If you are running more than one instance of Graylog server you have to select only one graylog-servernode as the leader.
Here is some insight, if you havenāt see this already.
Graylog 3.2
Graylog 4.3
Maybe @patrickmann could enlighten us ![]()
Yes, we have implemented automatic leader election. Currently, the default behavior is still static leader designation. But it can be configured as described here:
The word āmasterā has baggage, so we changed it to āleaderā at this time.
