Graylog Keeps Losing Leader
Every early morning, Graylog loses its leader
  • OS Information:
    All environments are Debian 12 within a LXD container hosted by PVE
  • Package Version:
    Graylog 5.1.5
    Mongodb 6.0.10
    opensearch 2.9.0
All server.confs are the same with the following difference:
is_leader = true applies to grayserver-1 / 192.168.1.1
is_leader = false applies to grayserver-{2,3} / 192.168.1.{2/3}
My setup:
I restart graylog-server.service and it resolves itself
I suspect that this is occurring because, as mentioned above, the nodes are hosted in a ProxMox environment and that I have ProxMox take a snapshot every night at or around midnight. However, before I remove that level of security, I wanted to ask the experts to ensure I am barking up the right tree.
Hey @accidentaladmin
I do have Proxmox but have not used snapshots, I started using FOG https://fogproject.org/
To be honest , I also think it has something to do with Proxmox. Personally I would montor the metric on all the nodes in the clusters during that time. I use Zabbix or what every you have.
You be able to see whats going on better, just an idea. Someone else had a similar issue with there Opensearch cluster while back something to do with there manager nodes/ data nodes in Opensearch forum.
Since you have cloudflare there should be something under Analytics & Logs and also check out caching there to, if you havent done that all ready.
Thank you for the breadcrumbs!
Fog looks interesting; I’ll check it out!
