To keep it simple, I was finally able to access the web interface on 9000 after opening the port of the local firewall in Centos. After I accessed the web interface, I notice the password was not working.
I went into the Server conf and noticed at the tail end of the sha2 some syntax has been accidentally added. I verified the correct sha2 output, updated the file and attempted to utilize my password. Didn’t work. The last thing I did was restart the GrayLog Server service, after that I’m not longer able to access the web interface.
I have checked to see if the server is listening for port 9000, which I verified before in troubleshooting, it’s no longer listening on the port.
I checked the conf file to see if I misplaced or accidentally deleted any lines, but everything looks good.
Working in a Centos 8 VM.
* Service logs, configurations, and environment variables:
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
password_secret =
[details="Summary"]
xOSecX6q6SiP7TkRrUisyUnNgaUshZHeraTGCj2q89stttYBtAiBY1j9MOC0rFsgwRVIi6sLzJ7GLaMNlolUgZvraOEsbJvJ
[/details]
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 =
[details="Summary"]
bfa499a69456adc9bdaa9341d16fd3fcf794a6769b4f812542987caf1c2d78c0
[/details]
_______________________________________________________
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1.:9000
http_bind_address = 10.10.50.82:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://$http_bind_address
#### External Graylog URI
# Default: $http_publish_uri
http_external_uri = $http_publish_uri
I just want to have a second pair of eyes to do a sanity check to keep me from going down unnecessary troubleshooting paths.
Thank you for any help or wisdom you can offer. I’ll keep cracking at this on my own in the mean time.
