I am working on a new installation of Graylog open. The service is running, but I can not access the web interface outside of the server. I am able to see the connections on the server, but no response from the service. The following is from the server.log. Any help is much appreciated. Thanks.
From the server.log:
2022-05-25T15:35:08.386-04:00 INFO [ServerBootstrap] Graylog server 4.2.9+f0d8298 starting up
2022-05-25T15:35:08.387-04:00 INFO [ServerBootstrap] JRE: Red Hat, Inc. 11.0.15 on Linux 4.18.0-348.23.1.el8_5.x86_64
2022-05-25T15:35:08.387-04:00 INFO [ServerBootstrap] Deployment: rpm
2022-05-25T15:35:08.387-04:00 INFO [ServerBootstrap] OS: Red Hat Enterprise Linux 8.5 (Ootpa) (rhel)
2022-05-25T15:35:08.387-04:00 INFO [ServerBootstrap] Arch: amd64
2022-05-25T15:35:08.424-04:00 INFO [PeriodicalsService] Starting 37 periodicals …
2022-05-25T15:35:13.626-04:00 INFO [ServerBootstrap] Graylog server up and running.
2022-05-25T15:35:13.626-04:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
The HTTP configuration:
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
# Modified from 9000 to 80 by DW on May 19, 2022
http_bind_address = 172.18.1.4:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
# Modified by DW on May 19, 2022
http_publish_uri = http://$http_bind_address/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri = $http_publish_uri
http_external_uri = http://$http_bind_address/
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
http_enable_cors = true
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
http_thread_pool_size = 16
Hello && Welcome
To help you further we would need more information ( hence, the Text Template should have explain this before posting).
The INFO logs that were post does not show what’s wrong, it also shows Graylog server starting up at that point.
Only reason you see this log because the enterprise plugin is install, This is common.
Reason I stated this, the issue could be multiple things, which I don’t wont to list every one here , what we need to do is narrow it down to a couple and troubleshoot.
Here are a couple ideas
- Check configuration
- Check permissions
- Check network on Graylog node.
- Check security devices
- Check browser/s
- Check resources ( i.e. cpu, ram, disk, etc…)
Thanks for the help. I did not realize the server team applied local firewall. Now the problem has been solved.
