Web interface login
Hello
I finally got Graylog up and running after rebuild. But I can’t log into the Web-interface. I use admin and the secret password the 64 characters. If that is right not working. Let me know.
Hello @studioman5150
This could be a few different issues, Can you show the Graylog Configuration file?
what do you need to see in the configuration file. Can’t copy the who file
sorry the whole file
This should help, just replace personal info.
 cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
is_master = true
password_secret = pyCf3pcYWXJpiDcYghAzOj3BBkji3Tu3qPqtJK9wuTgJF49KRUdolI9Ol8z4tFy82hEL9LRdurzyPIhRdAa2o5lM8H8OfEwi
root_password_sha2 = 63a9a81381068514c34263323aa6602be39bdfc9
http_bind_address = 127.0.0.1:9000
http_publish_uri = http://127.0.0.1:9000/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Try something easy for admin password ,you can always change it later.
echo -n password123| sha256sum
[root@graylog graylog]# echo -n password123| sha256sum
ef92b778bafe771e89245b89ecbc08a44a4e166c06659911881f383d4473e94f  -
Ensure you only copy the hash NOT “-”,
root_password_sha2 =  ef92b778bafe771e89245b89ecbc08a44a4e166c06659911881f383d4473e94f
Restart Graylog service
systemctl restart graylog-server
The rest looks good, if the only issue is with Password for admin, should be a easy fix as I showed above.
I did that but I can try again.
Check Graylog’s log file.
