Web Interface Connection Refused
When I attempt to connect to the web interface http://<local IP address>:9000 I get a connection refused error
I Have installed Greylog onto an Ubuntu server following the directions at http://docs.graylog.org/en/2.3/pages/installation/os/ubuntu.html
Elasticsearch and Greylog services show running.
Thanks in advance!
Please post your complete Graylog configuration file and check the logs of your Graylog node.
Here is a google drive link to the config file and two log files. Thanks for the help.
https://drive.google.com/drive/folders/0BzzJeutgRl2teXljeXRhTC11VXc?usp=sharing
You have to configure web_listen_uri correctly. My suggestion would be http://0.0.0.0:9000/.
Thank-you so much that got the web interface to prompt for a login. I did not realize I had to uncomment that line. I attempt to log in with the default admin/admin. but it says invalid credentials. I did not see a spot in the server.conf to change the password. I see where the root username can be changed but not the password.
Are there other lines of code I need to uncomment?
Thanks in advance,
Thank you so much for all the help. I have it up and running.
