WARNING: sun.reflect.Reflection.getCallerClass is not supported
Just installed Graylog 4.2.5 and upon checking the status of the Graylog service, I received the error message below. The server is up and running and I’m able to access it without issue.
Loaded: loaded (/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2022-01-10 23:16:19 UTC; 8s ago
Docs: http://docs.graylog.org/
Main PID: 2311489 (graylog-server)
Tasks: 103 (limit: 19110)
Memory: 809.7M
CGroup: /system.slice/graylog-server.service
├─2311489 /bin/sh /usr/share/graylog-server/bin/graylog-server
└─2311533 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true →
Jan 10 23:16:19 servername systemd[1]: Started Graylog server.
Jan 10 23:16:19 servername graylog-server[2311533]: WARNING: sun.reflect.Reflection.getCallerClass is not supported. This will impact performance.
  • OS Information: Ubuntu 20.04.3 LTS
  • Package Version:
    4.2.5
    servername:~$ java -version
    openjdk version “17.0.1” 2021-10-19
    OpenJDK Runtime Environment (build 17.0.1+12-Ubuntu-120.04)
    OpenJDK 64-Bit Server VM (build 17.0.1+12-Ubuntu-120.04, mixed mode, sharing)
Looked in the Community and scoured the web for anyone else that may have the same issue.
What concerns me most is the following line: “This will impact performance.” Has anyone seen this recently and if so, is there a resolution for it?
I have seen that issue here
https://coderedirect.com/questions/347020/is-log4j2-compatible-with-java-11
Hope that helps
Thanks, gsmith. I appreciate the help.
