Problem with Graylog "SLF4J: Failed to load class "
Hi everyone,
i have a problem with my Graylog Server, how can i solve it ?
graylog:# systemctl status graylog-server.service
Loaded: loaded (/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-01-20 16:20:59 CET; 13min ago
Docs: http://docs.graylog.org/
Main PID: 519 (graylog-server)
Tasks: 189 (limit: 9509)
Memory: 995.4M
CPU: 1min 21.809s
CGroup: /system.slice/graylog-server.service
├─519 /bin/sh /usr/share/graylog-server/bin/graylog-server
└─648 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadin>
Jan 20 16:20:59 graylog systemd[1]: Started Graylog server.
Jan 20 16:21:29 graylog01 [648]: SLF4J: Failed to load class “org.slf4j.impl.StaticLoggerBinder”.****
Jan 20 16:21:29 graylog01 [648]: SLF4J: Defaulting to no-operation (NOP) logger implementation
Jan 20 16:21:29 graylog01 [648]: SLF4J: See SLF4J Error Codes for further details.
Many Thanks ,
Peter.
Could this be a Plugin issue?
hi ,
I do not understand how I can solve it the link I do not understand. do I have to install a plugin?
thanks for your help,
peter
Do you have any plug-ins installed? If so, try to remove/disable them. That’s what I got from the thread.
Is this a new Graylog install?
Thank you, Zach.
hi ,
I only have Default Grok Patterns installed and Sources Page Dashboard. remove them?
Regards,
Peter
No. What version are you running? As a quick reminder from the FAQ/Guidelines, please ensure you provide what version you’re running when posting.
hi ,
I’m using graylog version Graylog v3.2.6 + e255fcc with elasticSearch 6.8.13
Regards,
Peter
Hi everyOne,
can someone help me how to remove tha terror in my graylog version Graylog v3.2.6 ?
error is Started Graylog server ,
Many thanks,
Peter
