Edit: figured it out.
Hi all,
Is is possible to run a query to display events& alarms history? The events and alarms hang around for a while but eventually disappear.
thanks
Darrin
Hi all,
thanks
Darrin
Good afternoon, you should be able to click on Alerts at the top of the UI and then change the history to look at. 365 days for example.
Thank you, Zach.
