User role to modify existing input
Server version: 2.3.2
Cluster of graylog nodes: 2 nodes in cluster
I want to create a role to edit existing inputs and assign it to a non admin user. After assigning the properties
  • inputs:edit
  • inputs:read
and assigning the role to user, the user still can’t edit any inputs. What other property should I add to that user to make it edit inputs?
Which error message do you see?
I don’t see any errors. When I go to “System -> inputs -> testinput-> more actions” there is nothing (like the edit input property or add static field"
So I added all inputs properties:
inputs:read
inputs:create
inputs:edit
inputs:terminate.
When I go to the dropdown input “More actions” I can only see “Delete input”
I can aswell create inputs in the input page, but edit seams it doesn’t work
Has anyone got into an issue like this before? Can I get some assistance?
There are specific permissions for extractors and static fields.
