I have a problem upgrading graylog from 4.3 to 5.0.
I suppose this should be a straighforward upgrade based on the videos but on my end its not working.
Please help.
Issue: Graylog 5.0 service is not starting.
Previous: graylog-server-4.3.13-1.noarch
Current : graylog-server-5.0.5-1.x86_64
There is no logs when I am starting the service so I am seeking help here.
java -version
openjdk version “17.0.1” 2021-10-19
OpenJDK Runtime Environment 21.9 (build 17.0.1+12)
OpenJDK 64-Bit Server VM 21.9 (build 17.0.1+12, mixed mode, sharing)
[root@graylogd01 yum.repos.d]#
# strace /usr/share/graylog-server/bin/graylog-server
execve("/usr/share/graylog-server/bin/graylog-server", ["/usr/share/graylog-server/bin/gr"...], 0x7ffc6df73c40 /* 25 vars */) = 0
brk(NULL) = 0xe4f000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa6632c7000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=45340, ...}) = 0
mmap(NULL, 45340, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fa6632bb000
close(3) = 0
open("/lib64/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\316\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=174576, ...}) = 0
mmap(NULL, 2268928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fa662e7d000
mprotect(0x7fa662ea2000, 2097152, PROT_NONE) = 0
mmap(0x7fa6630a2000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7fa6630a2000
close(3) = 0
open("/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\16\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=19248, ...}) = 0
mmap(NULL, 2109744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fa662c79000
mprotect(0x7fa662c7b000, 2097152, PROT_NONE) = 0
mmap(0x7fa662e7b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7fa662e7b000
close(3) = 0
open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`&\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=2156592, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa6632ba000
mmap(NULL, 3985920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fa6628ab000
mprotect(0x7fa662a6f000, 2093056, PROT_NONE) = 0
mmap(0x7fa662c6e000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c3000) = 0x7fa662c6e000
mmap(0x7fa662c74000, 16896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fa662c74000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa6632b8000
arch_prctl(ARCH_SET_FS, 0x7fa6632b8740) = 0
access("/etc/sysconfig/strcasecmp-nonascii", F_OK) = -1 ENOENT (No such file or directory)
mprotect(0x7fa662c6e000, 16384, PROT_READ) = 0
mprotect(0x7fa662e7b000, 4096, PROT_READ) = 0
mprotect(0x7fa6630a2000, 16384, PROT_READ) = 0
mprotect(0x6dd000, 4096, PROT_READ) = 0
mprotect(0x7fa6632c8000, 4096, PROT_READ) = 0
munmap(0x7fa6632bb000, 45340) = 0
rt_sigprocmask(SIG_BLOCK, NULL, [], 8) = 0
open("/dev/tty", O_RDWR|O_NONBLOCK) = 3
close(3) = 0
brk(0xe70000) = 0xe70000
brk(NULL) = 0xe70000
open("/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=106176928, ...}) = 0
mmap(NULL, 106176928, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fa65c368000
close(3) = 0
getuid() = 0
getgid() = 0
geteuid() = 0
getegid() = 0
open("/proc/meminfo", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa6632c6000
read(3, "MemTotal: 16265824 kB\nMemF"..., 1024) = 1024
close(3) = 0
munmap(0x7fa6632c6000, 4096) = 0
rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7fa6628e1400}, 8) = 0
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, 8) = 0
uname({sysname="Linux", nodename="graylogd01", ...}) = 0
stat("/etc/yum.repos.d", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getpid() = 22680
open("/usr/lib64/gconv/gconv-modules.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=26970, ...}) = 0
mmap(NULL, 26970, PROT_READ, MAP_SHARED, 3, 0) = 0x7fa6632c0000
close(3) = 0
getppid() = 22678
getpgrp() = 22678
rt_sigaction(SIGCHLD, {sa_handler=0x4414a0, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7fa6628e1400}, 8) = 0
getrlimit(RLIMIT_NPROC, {rlim_cur=63445, rlim_max=63445}) = 0
open("/usr/share/graylog-server/bin/graylog-server", O_RDONLY) = 3
ioctl(3, TCGETS, 0x7fff74be3ae0) = -1 ENOTTY (Inappropriate ioctl for device)
lseek(3, 0, SEEK_CUR) = 0
read(3, "#!/bin/sh\n\nset -e\n\n# For Debian/"..., 80) = 80
lseek(3, 0, SEEK_SET) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=4*1024}) = 0
fcntl(255, F_GETFD) = -1 EBADF (Bad file descriptor)
dup2(3, 255) = 255
close(3) = 0
fcntl(255, F_SETFD, FD_CLOEXEC) = 0
fcntl(255, F_GETFL) = 0x8000 (flags O_RDONLY|O_LARGEFILE)
fstat(255, {st_mode=S_IFREG|0755, st_size=915, ...}) = 0
lseek(255, 0, SEEK_CUR) = 0
read(255, "#!/bin/sh\n\nset -e\n\n# For Debian/"..., 915) = 915
stat("/etc/default/graylog-server", 0x7fff74be36b0) = -1 ENOENT (No such file or directory)
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
stat("/etc/sysconfig/graylog-server", {st_mode=S_IFREG|0644, st_size=535, ...}) = 0
open("/etc/sysconfig/graylog-server", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=535, ...}) = 0
read(3, "# Path to the java executable.\nJ"..., 535) = 535
close(3) = 0
stat("/usr/share/graylog-server/installation-source.sh", {st_mode=S_IFREG|0644, st_size=34, ...}) = 0
open("/usr/share/graylog-server/installation-source.sh", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=34, ...}) = 0
read(3, "GRAYLOG_INSTALLATION_SOURCE=\"rpm"..., 34) = 34
close(3) = 0
rt_sigprocmask(SIG_BLOCK, [INT CHLD], [], 8) = 0
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fa6632b8a10) = 22682
rt_sigprocmask(SIG_BLOCK, [CHLD], [], 8) = 0
rt_sigaction(SIGINT, {sa_handler=0x43e910, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, 8) = 0
wait4(-1, Unrecognized VM option 'UseConcMarkSweepGC'
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
[{WIFEXITED(s) && WEXITSTATUS(s) == 1}], 0, NULL) = 22682
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=22682, si_uid=0, si_status=1, si_utime=0, si_stime=2} ---
wait4(-1, 0x7fff74be32d0, WNOHANG, NULL) = -1 ECHILD (No child processes)
rt_sigreturn({mask=[]}) = 0
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, {sa_handler=0x43e910, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7fa6628e1400}, 8) = 0
exit_group(1) = ?
+++ exited with 1 +++
