Upgrading from 2.2.3 to 2.3.0
hi,
is a rolling update OK for upgrading from 2.2.3 to 2.3.0 ?
I tested with a single node setup, and it said
Legacy default stream has no connections, no migration needed.
So should it be OK just to add the elasticsearch_hosts line to the config file and then upgrade a multi-node setup one node at a time while running the other nodes?
Yes, this should be fine.
