After upgrade to version 3.2 from 3.1.x server don’t shows logs from sidecars and inputs. If i try go to inputs and click on “Show received messages” or go to sidecars and click on “show messages” i have only blank page with “Loading…” and no happen nothing. Below is my steps for upgrade and platform info.
Platform: Ubuntu 18.04.4 on ESXi 6.7
Deploy: from OVA image
I done steps from links:
1.#update-ova-to-latest-version
2.#operating-package-upgrade-deb-apt
but this command returns nothing, so i don’t do rest of commands. After above steps i start services (graylog-server and elasticsearch) and i was check status of services (started) and logs collecting (problem).
OVA is for POC - i know but i needed quick implementation. If the current problem will be resolved I have time to carry out the implementation from package.
How would you like to connect a stopped service?
The curl try to connect the elasticsearch. And you should get a error message.
Why stopped services? I checked with systemctl status graylog-server elasticsearch after upgrade whether services are active and running and after that i was check logs collecting.
But deflectors should working fine referring to server.log:
2020-03-20T17:57:58.655+01:00 INFO [MongoIndexSet] Cycling from <graylog_5> to <graylog_6>.
2020-03-20T17:57:58.655+01:00 INFO [MongoIndexSet] Creating target index <graylog_6>.
2020-03-20T17:57:58.679+01:00 INFO [Indices] Successfully created index template graylog-internal
2020-03-20T17:57:58.852+01:00 INFO [MongoIndexSet] Waiting for allocation of index <graylog_6>.
2020-03-20T17:57:58.854+01:00 INFO [MongoIndexSet] Index <graylog_6> has been successfully allocated.
2020-03-20T17:57:58.854+01:00 INFO [MongoIndexSet] Pointing index alias <graylog_deflector> to new index <graylog_6>.
2020-03-20T17:57:58.891+01:00 INFO [SystemJobManager] Submitted SystemJob <f3c523b0-6acb-11ea-bb1c-000c298d17da> [org.graylog2.indexer.indices.jobs.SetInde$
2020-03-20T17:57:58.891+01:00 INFO [MongoIndexSet] Successfully pointed index alias <graylog_deflector> to index <graylog_6>.
2020-03-20T17:58:28.913+01:00 INFO [SetIndexReadOnlyJob] Flushing old index <graylog_5>.
2020-03-20T17:58:29.535+01:00 INFO [SetIndexReadOnlyJob] Setting old index <graylog_5> to read-only.
2020-03-20T17:58:29.569+01:00 INFO [SystemJobManager] Submitted SystemJob <060e3b10-6acc-11ea-bb1c-000c298d17da> [org.graylog2.indexer.indices.jobs.Optimiz$
2020-03-20T17:58:29.593+01:00 INFO [CreateNewSingleIndexRangeJob] Calculating ranges for index graylog_5.
2020-03-20T17:58:29.596+01:00 INFO [OptimizeIndexJob] Optimizing index <graylog_5>.
2020-03-20T17:58:32.960+01:00 INFO [MongoIndexRangeService] Calculated range of [graylog_5] in [3365ms].
2020-03-20T17:58:32.961+01:00 INFO [CreateNewSingleIndexRangeJob] Created ranges for index graylog_5.
And i don’t have any error with deflectors but i have warn with beats:
2020-03-12T14:35:05.998+01:00 WARN [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=global_beats_for_networking, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=d51371f2-6491-4327-967a-085f382c757f} (channel [id: 0x10cf64ed, L:/0:0:0:0:0:0:0:0%0:11001]) should be 262144 but is 425984.
for index in `curl -s localhost:9200/_cat/aliases/*_deflector?h=index`; do curl -s -X PUT --data '{"properties":{"gl2_accounted_message_size":{"type": "long"}}}' -H Content-Type:application/json localhost:9200/$index/_mapping/message ; done
After above steps and restart services i’m able to see logs from sidecars and inputs.
