Upgrade to 3.2.2 breaks input
I just upgraded to graylog server from 3.0.2-1 to 3.2.2.
I restarted the server, and now the beats input isn’t working anymore :
2020-02-24T17:17:19.871+01:00 WARN  [ChannelInitializer] Failed to initialize a channel. Closing: [id: 0x1920999d, L:/10.144.102.68:5044 - R:/10.144.117.45:36846]
java.lang.IllegalArgumentException: TLSv1.3
        at sun.security.ssl.ProtocolVersion.valueOf(ProtocolVersion.java:187) ~[?:1.8.0_242]
        at sun.security.ssl.ProtocolList.convert(ProtocolList.java:84) ~[?:1.8.0_242]
        at sun.security.ssl.ProtocolList.<init>(ProtocolList.java:52) ~[?:1.8.0_242]
        at sun.security.ssl.SSLEngineImpl.setEnabledProtocols(SSLEngineImpl.java:2070) ~[?:1.8.0_242]
        at io.netty.handler.ssl.JdkSslContext.configureAndWrapEngine(JdkSslContext.java:341) ~[graylog.jar:?]
        at io.netty.handler.ssl.JdkSslContext.newEngine(JdkSslContext.java:330) ~[graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$3.createSslEngine(AbstractTcpTransport.java:338) ~[graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$3.call(AbstractTcpTransport.java:305) ~[graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$3.call(AbstractTcpTransport.java:301) ~[graylog.jar:?]
        at org.graylog2.plugin.inputs.transports.NettyTransport$1.initChannel(NettyTransport.java:105) ~[graylog.jar:?]
        at io.netty.channel.ChannelInitializer.initChannel(ChannelInitializer.java:129) [graylog.jar:?]
        at io.netty.channel.ChannelInitializer.handlerAdded(ChannelInitializer.java:112) [graylog.jar:?]
        at io.netty.channel.AbstractChannelHandlerContext.callHandlerAdded(AbstractChannelHandlerContext.java:956) [graylog.jar:?]
        at io.netty.channel.DefaultChannelPipeline.callHandlerAdded0(DefaultChannelPipeline.java:609) [graylog.jar:?]
        at io.netty.channel.DefaultChannelPipeline.access$100(DefaultChannelPipeline.java:46) [graylog.jar:?]
        at io.netty.channel.DefaultChannelPipeline$PendingHandlerAddedTask.execute(DefaultChannelPipeline.java:1463) [graylog.jar:?]
        at io.netty.channel.DefaultChannelPipeline.callHandlerAddedForAllHandlers(DefaultChannelPipeline.java:1115) [graylog.jar:?]
        at io.netty.channel.DefaultChannelPipeline.invokeHandlerAddedIfNeeded(DefaultChannelPipeline.java:650) [graylog.jar:?]
        at io.netty.channel.AbstractChannel$AbstractUnsafe.register0(AbstractChannel.java:502) [graylog.jar:?]
        at io.netty.channel.AbstractChannel$AbstractUnsafe.access$200(AbstractChannel.java:417) [graylog.jar:?]
        at io.netty.channel.AbstractChannel$AbstractUnsafe$1.run(AbstractChannel.java:474) [graylog.jar:?]
        at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:164) [graylog.jar:?]
        at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:472) [graylog.jar:?]
        at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:500) [graylog.jar:?]
        at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) [graylog.jar:?]
        at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [graylog.jar:?]
        at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_242]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_242]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
Is ther any way to fix this ?
thanks
Do you have the enabled_tls_protocols option set in your server.conf?
https://docs.graylog.org/en/latest/pages/upgrade/graylog-3.2.html#configuration-file-changes
https://docs.graylog.org/en/latest/pages/configuration/server.conf.html#server-conf
Hi @Ponet
indeed this waht I missed in the documentation.
Setting to TLSv1.2 fixed the isssue.
Many thanks
@romgo
Weird, I thought I’ve tested this.
Which jdk version are you using? did you change the transport_netty_tls_provider setting?
I do use :
# java -version
openjdk version "1.8.0_242"
OpenJDK Runtime Environment (build 1.8.0_242-8u242-b08-1~deb9u1-b08)
OpenJDK 64-Bit Server VM (build 25.242-b08, mixed mode)
I didn’t change transport_netty_tls_provider option.
To make it work I had to set enabled_tls_protocols = TLSv1.2 into server.conf
Hope this help.
Hmm,
I guess this is because you’re running Debian 9
Do you see any errors about libnetty in your server.log?
indeed I’m running debian 9.
I don’t see any error in server.log file.
