Unable to start inputs after implementing HTTPS on Graylog web interface
Issue summary:
I have implemented https/TLS on the Graylog web interface following this guide: Using HTTPS - Configuring Graylog
billede
Now, I’ve got https working on the website, but now my syslog UDP inputs are unable to start - including the new syslog TCP input I just created:
My environment:
Graylog 4.2.4+b643d2b on (Debian 10 on Linux 4.19.0-18-amd64)
Logs:
2022-01-06T08:31:57.929+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/metrics/multiple on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:57.940+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.023+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates/61d5ab8834b9fa6fd275c639 on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.086+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.146+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates/61d5ab8834b9fa6fd275c639 on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.205+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.287+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates/61d5ab8834b9fa6fd275c639 on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.353+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.931+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/metrics/multiple on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:31:59.941+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:32:01.926+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/metrics/multiple on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
2022-01-06T08:32:01.937+01:00 WARN [ProxiedResource] Unable to call https://graylog.[domain redacted].com:9000/api/system/inputstates on node <265afac6-d5af-47ae-b107-7f61973c5a05>: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Troubleshooting steps taken:
None, really, as I don’t quite know what’s causing these errors.
So… what have I missed, or what might I be doing wrong?
Please do let me know if any important bits of information are missing, and I’ll make sure to update the thread accordingly.
Where it says “unable to find certification path”. Make sure graylog can access where the certificate are located.
chown graylog:graylog -R /etc/graylog/server/
Next, is this certificate listed as a trusted certificates of your JVM?
Also did you set your Keystore? If not, In order for the JVM to pick up the new trust store, it has to be started with the JVM parameter
-Djavax.net.ssl.trustStore=/path/to/cacerts.jks
Which in your case should be here.
/etc/default/graylog-server
EDIT: I’m not 100% sure but are you using the right certificates for your input?
If you followed that documentation, you should have the following certs.
(graylog-key.pem) and the X.509 certificate (graylog-certificate.pem)
Hope that helps
Blockquote
Access/permissions should not be an issue:
billede
And, again, the web interface is working with the cert (can access via https).
Blockquote
I’m not too sure about this java keystore stuff, but here is exactly what I did:
cd /etc/graylog/server
sudo cp /etc/ssl/certs/java/cacerts .
(above path was determined using this article: https://www.baeldung.com/find-java-home)
sudo keytool -importcert -keystore /etc/graylog/server/cacerts -storepass changeit -alias graylog-self-signed -file cert.pem
sudo vi /etc/elasticsearch/jvm.options
Add the following line to the very end of jvm.options config file:
-Djavax.net.ssl.trustStore=/etc/graylog/server/cacerts
Save & exit VI
I have had this issue before which I was able to log into the web interface but my Inputs were not working.
My check list consist of the following.
  • Make sure I’m actually using the correct certificates.
  • Check Keystore for the correct certificates were installed.
  • Make sure I created the proper keystore.
  • Permission on the Certificates must be owned by Graylog, if not Graylog will be unable to find certification path.
So the moral of the story is…
This could be an error on your certificate/s created, OR your using a incorrect one for your input.
Here are a couple post you may want to look at, This helped for understanding what I need to do.
Hope that helps
Ok, I finally managed to get TLS encryption working on the web interface while still being able to start my inputs. Next up is figuring out how to actually get a client to send TLS encrypted syslog input to Graylog.
These are the steps I followed to get things working on my Debian 10 box (thanks to user @dickinsonzach who post this solution: After SSL - Hostname not verified - #12 by dickinsonzach):
Start out by changing directory into /etc/graylog/server
Then do:
sudo vi openssl-graylog.cnf
Insert the following:
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
[req_distinguished_name]
C = input countrycode
L = input city
O = input organisation name
OU = insert department name
CN = insert graylog FQDN (i.e. graylog.yourdomain.com)
[v3_req]
keyUsage = keyEncipherment, dataEncipherment, nonRepudiation, digitalSignature
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
[alt_names]
IP.1 = insert IP-address of graylog server
DNS.1 = insert graylog FQDN
Save & exit VI.
Now create a certificate using the config we just set up:
sudo openssl req -x509 -days 1095 -nodes -newkey rsa:4096 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out cert.pem
Convert the pkcs5 file into pkcs8 format:
sudo openssl pkcs8 -in pkcs5-plain.pem -topk8 -nocrypt -out pkcs8-plain.pem
Create an encrypted version of the pkcs8 certificate file:
sudo openssl pkcs8 -in pkcs5-plain.pem -topk8 -out pkcs8-encrypted.pem -passout pass:*insert a cert passphrase*
Import the cert.pem created initially, into the keystore:
sudo keytool -importcert -keystore /etc/ssl/certs/java/cacerts -storepass changeit -alias *insert graylog FQDN* -file cert.pem
Give the graylog user ownership of all the certs:
sudo chown -R graylog:graylog /etc/graylog/
Edit the graylog server config to enable TLS encryption:
sudo vi /etc/graylog/server/server.conf
In section “HTTPS settings”, make changes like so:
http_enable_tls = true
http_tls_cert_file = /etc/graylog/cert.pem
http_tls_key_file = /etc/graylog/pkcs8-encrypted.pem
http_tls_key_password = [insert cert passphrase]
Finally, do:
systemctl restart graylog-server.service
And test that Graylog web interface can now be accessed over https - https://insert graylog FQDN:9000/
Also check that the inputs are still working/running.
That’s awesome.
I used nxlog for my log shipper. You could either use it a single install ( DL it from the web site) OR use Graylog-Sidecar but the configuration file should be the same.
This is an Example of one client in my lab.
NXLOG_Config
define CERTDIR %ROOT%\cert  <-- This is where I store my certs on Windows OS
define LOGFILE C:\Program Files (x86)\nxlog\data\nxlog.log
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
LogFile %ROOT%\data\nxlog.log
<Extension _fileop>
    Module xm_fileop
    # Check the log file size every hour and rotate if larger than 5 MB
    <Schedule>
        Every 1 hour
        <Exec>
            if (file_exists('%LOGFILE%') and file_size('%LOGFILE%') >= 5M)
                file_cycle('%LOGFILE%', 8);
        </Exec>
    </Schedule>
    # Rotate log file every week on Sunday at midnight
    <Schedule>
        When    @weekly
        Exec    if file_exists('%LOGFILE%') file_cycle('%LOGFILE%', 8);
    </Schedule>
</Extension>
<Extension gelf>
    Module      xm_gelf
 </Extension>
<Input in>
    Module      im_msvistalog
</Input>
<Output out>
    Module      om_ssl
    Host        graylog.domain.com
    Port        51412
    OutputType  GELF_TCP
    CertFile    %CERTDIR%/graylog3-certificate.pem
    CertKeyFile %CERTDIR%/graylog3-key.pem
    CAFile      %CERTDIR%/cert3.pem
    KeyPass     secret
    AllowUntrusted  true
    Exec $Hostname = hostname_fqdn();
    Exec $FullMessage = $raw_event;
    #Exec        to_syslog_snare();
</Output>
<Route >
    Path        in => out
</Route>
EDIT: I should made mention that I was using GELF input TLS/TCP.
I think this is what you wanted.
If you don’t want tot go that route Graylog-Sidecar is a better option. You can find more here
Hope that helps
