Upgrade to 2.4.6
Just ran the upgrade to 2.4.6 and I’m not sure if this is cosmetic or indicative of an issue with the upgrade. When I logged in after the upgrade, I’m still showing Graylog 2.4.5+8e18e6a as the version on the footer of the webpage. I’m not sure where else to check the version in the GUI.
Which brings up a bit of a feature request (I’ll post in the appropriate spot for that also). Can you add an about section to the help menu in Graylog that will list the version?
Is there a definitive way to see the version currently running? either CLI or GUI?
Thanks!
Nevermind… figured it out… was pulling cached images… CTRL+F5 and the footer now displays the correct version.
Graylog 2.4.6+ceaa7e4
So it seems the upgrade succeeded just fine.
