Hi all, requesting your advise and inputs regarding upgrade options for Graylog Enterprise 4.2.5 on arm64.
I have this notification every few hours " You are running an outdated Graylog version. The most recent stable Graylog version is 4.2.8 (Noir) released at 2022-04-12T00:00:00.000Z "
Based on what I looked up, the last release of Graylog-enterprise for arm64 was 4.2.5
OS Information:
Graylog Enterprise 4.2.5 running as a containerized app within docker, on arm64 platform.
I;m using docker-compose.yml file to define the Graylog environment/startup parameters, as well as been using it to perform upgrades (through tags) -
Package Version:
4.2.5
Based on the available tags for arm64 ( graylog/graylog-enterprise Tags | Docker Hub
- the last Graylog release was 4.2.5 about 4 months back
All subsequent releases (4.2.6, 4.2.7 , 4.2.8) have been releases ONLY for amd64.
Now I do see 4.2.8 released both for amd64 & arm64 - but this I presume is the OSS graylog image and NOT the enterprise image graylog/graylog Tags | Docker Hub
Please advise if here are any upgrade options available for Graylog Enterprise on arm64 post release 4.2.5.
Thanks for your time
