Upgrade Graylog 5.2 to 6.0
5.2 –> 6.0
Hello. During the update process, I see the following message.
Errors during downloading metadata for repository ‘graylog
it sounds like there’s an issue with the repository. I might try deleting it and re-adding.
Can I download this file separately?repomd.xml?
No, but if you delete the repository and re-add it, the issue might clear up. I would see if you can find instructions for your OS.
Im tried delete repos but problem not resolve(delete /etc/yum.repos.d/greylog.repo ). Can i cancel this check with repomd.xml?
I don’t know - I think at this point you probably need more general Linux assistance than anything having to do with Graylog.
