Update not shown running 5.0.7.1 (5.0.7+ in gui) for 5.2
Trying to update Graylog open from 5.0.7.1 to 5.2. Followed the guide, but when I search the available versions it is only listing my 5.0.7.1 as the latest.
  • OS Information:
    SUSE 15 SP4
  • Package Version:
gray:~ # sudo zypper info graylog-server
Refreshing service ‘Basesystem_Module_15_SP4_x86_64’.
Refreshing service ‘Desktop_Applications_Module_15_SP4_x86_64’.
Refreshing service ‘Development_Tools_Module_15_SP4_x86_64’.
Refreshing service ‘Python_3_Module_15_SP4_x86_64’.
Refreshing service ‘SUSE_Linux_Enterprise_Server_15_SP4_x86_64’.
Refreshing service ‘SUSE_Package_Hub_15_SP4_x86_64’.
Refreshing service ‘Server_Applications_Module_15_SP4_x86_64’.
Loading repository data…
Reading installed packages…
Information for package graylog-server:
Repository : graylog
Version : 5.0.7-1
Arch : x86_64
Vendor : graylog
Support Level : unknown
Installed Size : 285.0 MiB
Installed : Yes
Status : up-to-date
Source package : graylog-server-5.0.7-1.src
Upstream URL : https://www.graylog.org/
Summary : Graylog server
Description :
Graylog server
    Unsure what else to supply other than all the data I’ve included already, but willing to add more :slight_smile:
Other than following the guide (and the little common sense I have other than that)… Here’s some snippets of things I’ve done and the result:
gray:~ # sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-5.2-repository_latest.rpm
Retrieving https://packages.graylog2.org/repo/packages/graylog-5.2-repository_latest.rpm
warning: /var/tmp/rpm-tmp.KThjPU: Header V4 RSA/SHA256 Signature, key ID b1606f22: NOKEY
Preparing… ################################# [100%]
Updating / installing…
1:graylog-5.2-repository-1-2 ################################# [ 50%]
Cleaning up / removing…
2:graylog-5.0-repository-1-2 ################################# [100%]
gray:~ # sudo zypper update
Nothing to do.
then ran:
gray:~ # sudo zypper search -s graylog-server
S | Name | Type | Version | Arch | Repository
i+ | graylog-server | package | 5.0.7-1 | x86_64 | graylog
v | graylog-server | package | 5.0.6-1 | x86_64 | graylog
v | graylog-server | package | 5.0.5-1 | x86_64 | graylog
v | graylog-server | package | 5.0.4-1 | x86_64 | graylog
v | graylog-server | package | 5.0.3-1 | x86_64 | graylog
v | graylog-server | package | 5.0.2-1 | x86_64 | graylog
v | graylog-server | package | 5.0.1-1 | x86_64 | graylog
v | graylog-server | package | 5.0.0-14 | x86_64 | graylog
v | graylog-server | package | 5.0.0-13.rc.2 | x86_64 | graylog
v | graylog-server | package | 5.0.0-12.rc.1 | x86_64 | graylog
v | graylog-server | package | 5.0.0-11.beta.5 | x86_64 | graylog
v | graylog-server | package | 5.0.0-10.beta.5 | x86_64 | graylog
v | graylog-server | package | 5.0.0-9.beta.4 | x86_64 | graylog
v | graylog-server | package | 5.0.0-8.beta.3 | x86_64 | graylog
v | graylog-server | package | 5.0.0-7.beta.2 | x86_64 | graylog
v | graylog-server | package | 5.0.0-6.beta.1 | x86_64 | graylog
Note that 5.0.7-1 is the latest available. ;(
Ran the rpm command again and it shows the 5.2 files should be there:
package graylog-5.2-repository-1-2.noarch is already installed
gray:~ # zypper update
Nothing to do.
Trying to figure out why my device cannot see there are newer versions than 5.0.7-1 available. 5.2 has identical requirements as 5.0.x, and my 5.0.7-1 (may have been updated once to get to -1, can’t remember) but graylog has been running here for over a year. Just won’t update. And running the recommended SUSE 15… Any ideas without breaking it or doing an entire new install?
Thanks in advance!!
Hey @rooster
You may have to remove the old repo and run a update, then try Upgrade not an update.
Not sure what I’m doing wrong… It doesn’t seem to let me remove it, but it also doesn’t seem to exist (either one, the original ‘graylog-server’ nor the one with the referenced 5.2 in it… Here’s the commands I ran and their output:
gray:/etc/zypp/repos.d # zypper up graylog-server
‘graylog-server’ is already installed.
Package ‘graylog-server’ is not available in your repositories. Cannot reinstall, upgrade, or downgrade.
Resolving package dependencies…
Nothing to do.
gray:/etc/zypp/repos.d # zypper search graylog
S | Name | Summary | Type
i+ | graylog-5.2-repository | Package to install Graylog 5.2 GPG key and repository | package
i+ | graylog-server | Graylog server | package
Note: For an extended search including not yet activated remote resources please use 'zypper
search-packages'.
gray:/etc/zypp/repos.d # zypper rr graylog-server
Repository ‘graylog-server’ not found by alias, number or URI.
gray:/etc/zypp/repos.d # zypper lr
Repository priorities are without effect. All enabled repositories share the same priority.
| Alias | Name | Enabled | GPG Check | Refresh
1 | Basesystem_Module_15_SP4_x86_64:SLE-Module-Basesystem15-SP4-Debuginfo-Pool | SLE-Module-Basesystem15-SP4-Debuginfo-Pool | No | ---- | ----
2 | Basesystem_Module_15_SP4_x86_64:SLE-Module-Basesystem15-SP4-Debuginfo-Updates | SLE-Module-Basesystem15-SP4-Debuginfo-Updates | No | ---- | ----
3 | Basesystem_Module_15_SP4_x86_64:SLE-Module-Basesystem15-SP4-Pool | SLE-Module-Basesystem15-SP4-Pool | Yes | (r ) Yes | No
4 | Basesystem_Module_15_SP4_x86_64:SLE-Module-Basesystem15-SP4-Source-Pool | SLE-Module-Basesystem15-SP4-Source-Pool | No | ---- | ----
5 | Basesystem_Module_15_SP4_x86_64:SLE-Module-Basesystem15-SP4-Updates | SLE-Module-Basesystem15-SP4-Updates | Yes | (r ) Yes | Yes
6 | Desktop_Applications_Module_15_SP4_x86_64:SLE-Module-Desktop-Applications15-SP4-Debuginfo-Pool | SLE-Module-Desktop-Applications15-SP4-Debuginfo-Pool | No | ---- | ----
7 | Desktop_Applications_Module_15_SP4_x86_64:SLE-Module-Desktop-Applications15-SP4-Debuginfo-Updates | SLE-Module-Desktop-Applications15-SP4-Debuginfo-Updates | No | ---- | ----
8 | Desktop_Applications_Module_15_SP4_x86_64:SLE-Module-Desktop-Applications15-SP4-Pool | SLE-Module-Desktop-Applications15-SP4-Pool | Yes | (r ) Yes | No
9 | Desktop_Applications_Module_15_SP4_x86_64:SLE-Module-Desktop-Applications15-SP4-Source-Pool | SLE-Module-Desktop-Applications15-SP4-Source-Pool | No | ---- | ----
10 | Desktop_Applications_Module_15_SP4_x86_64:SLE-Module-Desktop-Applications15-SP4-Updates | SLE-Module-Desktop-Applications15-SP4-Updates | Yes | (r ) Yes | Yes
11 | Development_Tools_Module_15_SP4_x86_64:SLE-Module-DevTools15-SP4-Debuginfo-Pool | SLE-Module-DevTools15-SP4-Debuginfo-Pool | No | ---- | ----
12 | Development_Tools_Module_15_SP4_x86_64:SLE-Module-DevTools15-SP4-Debuginfo-Updates | SLE-Module-DevTools15-SP4-Debuginfo-Updates | No | ---- | ----
13 | Development_Tools_Module_15_SP4_x86_64:SLE-Module-DevTools15-SP4-Pool | SLE-Module-DevTools15-SP4-Pool | Yes | (r ) Yes | No
14 | Development_Tools_Module_15_SP4_x86_64:SLE-Module-DevTools15-SP4-Source-Pool | SLE-Module-DevTools15-SP4-Source-Pool | No | ---- | ----
15 | Development_Tools_Module_15_SP4_x86_64:SLE-Module-DevTools15-SP4-Updates | SLE-Module-DevTools15-SP4-Updates | Yes | (r ) Yes | Yes
16 | Python_3_Module_15_SP4_x86_64:SLE-Module-Python3-15-SP4-Debuginfo-Pool | SLE-Module-Python3-15-SP4-Debuginfo-Pool | No | ---- | ----
17 | Python_3_Module_15_SP4_x86_64:SLE-Module-Python3-15-SP4-Debuginfo-Updates | SLE-Module-Python3-15-SP4-Debuginfo-Updates | No | ---- | ----
18 | Python_3_Module_15_SP4_x86_64:SLE-Module-Python3-15-SP4-Pool | SLE-Module-Python3-15-SP4-Pool | Yes | (r ) Yes | No
19 | Python_3_Module_15_SP4_x86_64:SLE-Module-Python3-15-SP4-Source-Pool | SLE-Module-Python3-15-SP4-Source-Pool | No | ---- | ----
20 | Python_3_Module_15_SP4_x86_64:SLE-Module-Python3-15-SP4-Updates | SLE-Module-Python3-15-SP4-Updates | Yes | (r ) Yes | Yes
21 | SLES15-SP4-15.4-0 | SLES15-SP4-15.4-0 | No | ---- | ----
22 | SUSE_Linux_Enterprise_Server_15_SP4_x86_64:SLE-Product-SLES15-SP4-Debuginfo-Pool | SLE-Product-SLES15-SP4-Debuginfo-Pool | No | ---- | ----
23 | SUSE_Linux_Enterprise_Server_15_SP4_x86_64:SLE-Product-SLES15-SP4-Debuginfo-Updates | SLE-Product-SLES15-SP4-Debuginfo-Updates | No | ---- | ----
24 | SUSE_Linux_Enterprise_Server_15_SP4_x86_64:SLE-Product-SLES15-SP4-Pool | SLE-Product-SLES15-SP4-Pool | Yes | (r ) Yes | No
25 | SUSE_Linux_Enterprise_Server_15_SP4_x86_64:SLE-Product-SLES15-SP4-Source-Pool | SLE-Product-SLES15-SP4-Source-Pool | No | ---- | ----
26 | SUSE_Linux_Enterprise_Server_15_SP4_x86_64:SLE-Product-SLES15-SP4-Updates | SLE-Product-SLES15-SP4-Updates | Yes | (r ) Yes | Yes
27 | SUSE_Package_Hub_15_SP4_x86_64:SLE-Module-Packagehub-Subpackages15-SP4-Debuginfo-Pool | SLE-Module-Packagehub-Subpackages15-SP4-Debuginfo-Pool | No | ---- | ----
28 | SUSE_Package_Hub_15_SP4_x86_64:SLE-Module-Packagehub-Subpackages15-SP4-Debuginfo-Updates | SLE-Module-Packagehub-Subpackages15-SP4-Debuginfo-Updates | No | ---- | ----
29 | SUSE_Package_Hub_15_SP4_x86_64:SLE-Module-Packagehub-Subpackages15-SP4-Pool | SLE-Module-Packagehub-Subpackages15-SP4-Pool | Yes | (r ) Yes | No
30 | SUSE_Package_Hub_15_SP4_x86_64:SLE-Module-Packagehub-Subpackages15-SP4-Source-Pool | SLE-Module-Packagehub-Subpackages15-SP4-Source-Pool | No | ---- | ----
31 | SUSE_Package_Hub_15_SP4_x86_64:SLE-Module-Packagehub-Subpackages15-SP4-Updates | SLE-Module-Packagehub-Subpackages15-SP4-Updates | Yes | (r ) Yes | Yes
32 | SUSE_Package_Hub_15_SP4_x86_64:SUSE-PackageHub-15-SP4-Backports-Debuginfo | SUSE-PackageHub-15-SP4-Backports-Debuginfo | No | ---- | ----
33 | SUSE_Package_Hub_15_SP4_x86_64:SUSE-PackageHub-15-SP4-Backports-Pool | SUSE-PackageHub-15-SP4-Backports-Pool | Yes | (r ) Yes | No
34 | SUSE_Package_Hub_15_SP4_x86_64:SUSE-PackageHub-15-SP4-Pool | SUSE-PackageHub-15-SP4-Pool | Yes | (r ) Yes | No
35 | Server_Applications_Module_15_SP4_x86_64:SLE-Module-Server-Applications15-SP4-Debuginfo-Pool | SLE-Module-Server-Applications15-SP4-Debuginfo-Pool | No | ---- | ----
36 | Server_Applications_Module_15_SP4_x86_64:SLE-Module-Server-Applications15-SP4-Debuginfo-Updates | SLE-Module-Server-Applications15-SP4-Debuginfo-Updates | No | ---- | ----
37 | Server_Applications_Module_15_SP4_x86_64:SLE-Module-Server-Applications15-SP4-Pool | SLE-Module-Server-Applications15-SP4-Pool | Yes | (r ) Yes | No
38 | Server_Applications_Module_15_SP4_x86_64:SLE-Module-Server-Applications15-SP4-Source-Pool | SLE-Module-Server-Applications15-SP4-Source-Pool | No | ---- | ----
39 | Server_Applications_Module_15_SP4_x86_64:SLE-Module-Server-Applications15-SP4-Updates | SLE-Module-Server-Applications15-SP4-Updates | Yes | (r ) Yes | Yes
40 | elasticsearch-7.10.2 | Elasticsearch repository for 7.10.2 packages | Yes | (r ) Yes | Yes
41 | mongodb | mongodb | Yes | (r ) Yes | No
42 | opensearch-2.x | OpenSearch 2.x | Yes | (r ) Yes | Yes
Thanks in advance!
Hey,
Not sure what going on with repository. How did you install Graylog?
RPM?
Honestly, I’m not sure - I walked into this project within our team about a few months ago, the previous gentleman did the original/initial setup on it, and left it as sort of a proof of concept. He was alone on it, as I am now, we left before I was brought in on it so there was no conversation time. He had set up a whopplng two agents in our environment, which I have upped to about 80, multiple input types (I am gathering/storing mostly windows event logs, but also any hardware that supports syslog) to essentially be a one-stop shop for any and all noteworthy data… :slight_smile:
Based on what I’ve read and can ascertain, I’m thinking he downloaded this manually, as there was never a graylog-server-5.0.x style repo. all I see is the one I added for 5.2 and a graylog-server, the one I can’t seem to get rid of, lol.
I can get around in linux, but am no mater by any means, and just not sure why the zypper rr graylog-server refuses to get rid of it, nor why the package list doesn’t show EITHER of the graylog packages.
Hoping someone will have an idea/suggestion/solution… I mean, it’s running well on 5.0.7+ but you know, would like it to stay current :slight_smile:
Thanks!
Yeah that has to suck, been there before walking into a sh$t storm.
Not sure if you seen this here, check if that guy made a repo
here /etc/zypp/repos.d/graylog.repo.
It might look like this:
[graylog]
name=graylog
baseurl=https://packages.graylog2.org/repo/el/stable/5.0/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/GPG-KEY-graylog
repo_gpgcheck=0
You could change the version number fro “0” to “2” and reload/refresh your repo. As for working with SUSE, there all a little different on the commands , but the object is the same, meaning new repo needs to be updated/ refreshed then install the version.
Chances are the rest should be good.
Not sure if he install the Open version or Enterprise version. I would look at the command history see what up.
