It’s possible to setup agregation for alert (notification) for unique values?
I tried:
If
count() - variable > 1
variable is value returned from messages
I using graylog v3.1.3
I tried:
If
Hi gertz,
the screenshot was made with 3.2 but this should do the trick with 3.1
It alerts when in the last 4 minute a message exists only 1 time.
If you meant something else, let me know and we figure something out.
I have hundreds messages per day like
CN=25-484-154
CN=25-484-154
CN=25-447-154
CN=25-484-154
CN=25-447-154
CN=25-447-154
this is CN=25-447-154 already extracted from patern. (in my prev. mess. it was VARIABLE)
and I need to send wia mail just something like.
CN=25-447-154
CN=25-484-154
Can you describe me the condition in your words when the email needs to be send?
I am not able to see the pattern when you want to send the email. But I am pretty sure we will find a solution.
Best regards,
Konrad
I have lot of devices with expire certificate and from logs (what send one host) I extrac ID of device like: CN=25-484-154, but that device send this error many times per hour. I need only send information in one mail with all device ID whitch is unique withou duplicity.
my patern for value CN=[\s*a-zA-Z0-9._-]+
search query: “VERIFY ERROR: depth=0, error=certificate has expired: CN=”
sending on daily base
@gertz I had now a longer conversation with one of the developers. This gonna be a rough ride, so fasten your seat belt.
I might have a solution where you would get one email for every unique indecent, which you could configure a grace period for a couple of hours/days. That way the noise in the messages would be reduced.
CN. If now then you should do so now._exists_:CN:Next to the tab Fields.http_method with your field name CN.CN every 5 hours.That should do the trick. I hope this helps. Let me know if something is not clear.
Best regards,
Konrad
Thank you for fast reply I will try your solution, its better that 500+ mails per day
