I received multiple mail with weird message into it.
Into my mail, I received the same message multiple time. Can I combine the sources in one message?
Can I get only one message from the source
I’ve create the Events for Definition with the different count.
Thank you
m_mlk
November 18, 2022, 7:38am
2
Hi @MickGraylog1
this is exactly the problem I described in my post:
we have defined an alert based on an event.
The filter we use yields several results and that is fine.
The notification tab is configured to have a “Grace Period = 0” and “Message Backlog = 50” (at least for now).
However, instead of getting 1 single email with a backlog of up to 50 error messages, I receive 1 email per message line… not cool.
OS Information: Ubuntu 20.04 LTS
Package Version: GL 4.3.9 + OpenSearch 1.3.3
Servi…
Hopefully someone will shed some light in this…
Cheers
You need to set up an aggregation.
Here’s a thread that looks like the same issue:
Hello, I am try to send email alerts when a Stream has events. I want to check the stream every 10 minutes, and if there were any events at all during the last 10 minutes, then send an email with a list of those events. From the settings shown below, I thought I had it setup correctly, however it is not working as intended. Whenever there is an Event (even milliseconds apart), it generates a notification for every event. I want it to only generate a notification up to every 10 minutes, and t…
Thank you so much guys for your guide.
The solution was the aggregation :
if
count() - nothing in field - > 0
and it’s working perfectly, the only problem is I have duplicate source into the problem.
When I tried to add an if max source = 1, nothing happen else.
Thank you!
