Unexpected behavior for handling numeric field
I’m trying Graylog 3.0 and it seems it has some unclear behavior about detecting field type and managing it.
I extract request time from Nginx logs using grok pattern %{BASE10NUM:req_time},
Field extracted properly and for further analysis I’m trying to generate charts and statistics.
Expected result:
It’s possible to query logs by request time field
It’s possible to query logs by request time field value (for example requests took more than 1 second)
It’s possible to generate statistics for numeric type(including max, min, deviation, etc)
It’s possible to generate chart and customize it by max, mean, and so on
Actual result:
It’s not possible to generate statistics for numeric type(including max, min, deviation, etc), all those fields displayed as NA
It’s not possible to generate chart and customize it by max, mean, and so on - chart is not updated accordingly.
The same log with the same extractor can be analyzed as expected on Graylog 2.5.1
maybe forgot mention to index your fields as number in elasticsearch
use elasticsearch mapping.
http://docs.graylog.org/en/2.4/pages/configuration/index_model.html
http://docs.graylog.org/en/2.4/pages/configuration/elasticsearch.html
Thanks, I will check, but in both cases I use default out-of-the-box configuration and don’t customize Elasticsearch related settings.
Update: Yes, @macko003, you’re right, in good case this field is float, and in bad case it’s keyword.
Is there any way to change default Graylog configuration to avoid manual convert operations?
Update2: grok pattern can include field type, so it seems I have to use it
Could you show how do you do it?
I think you missed it with the grok pattern.
As far as I know elastic handle every field as text. You have to override it with custom mapping. (I shared the link how can you do it.
Like this:
http://docs.graylog.org/en/3.0/pages/extractors.html
%{NUMBER:request_time;float}
After I changed this pattern I verified ES mappings and confirmed field has correct type
Thanks, it’s new for me!
