Unclear extractor options
I am attempting to create an extractor. So far, so good, however there are two options that do not appear in documentation and I do not understand what they do.
  • Named captures only
  • Extraction strategy
Q: What do these options do?
he @NominaSumpta
welcome to the community. Named captures only is for Grok based extractors. This means that you will get only fields extracted that you give a name and not all possible matched fields.
Examples first with Named captures only unchecked and second with checked.
(I have used https://grokdebug.herokuapp.com/ for this)
It is very likely that you want the second option!
Docs https://docs.graylog.org/en/3.2/pages/extractors.html#using-grok-patterns-to-extract-data
for Extraction strategy - what is your exact question that is not answered by the text below that field?
