Grok Pipeline only_named_captures
I have no idea how to only capture named grok patterns.
Here is my pipeline config:
rule “HourExtractor”
has_field(“TimeStamp”)
let Time = to_string($message.TimeStamp);
let Hour = grok(“%{DATA:UNWANTED}T%{NUMBER:Hour}%{DATA:UNWANTED}”, Time);
set_fields(Hour);
I have tried adding things such as: “, True” after “Time” and it won’t work at all, I’m sure it’s extremely simple, but I just can’t work it out and there aren’t many examples online.
Cheers,
G
Okay so it was just:
let Hour = grok("%{DATA:UNWANTED}T%{NUMBER:Hour}%{DATA:UNWANTED}", Time, true);
I must have tried about every other similar combination apart from just true.
you could have also used:
let nexus = grok(pattern: "%{GROKPATTERNS}", value: message_field, only_named_captures: true);
To be more human readable.
