Unable to use pipeline for nested json
Hey,
I want to pipeline to set fields for the below mentioned json .However I am unable to do so.
Json example:
{“Message”:“124”, “data”:{“MT”:“msgtype”, “UID”:“123abc”}}
I need set fields for the inner json fields MT and UID along with message.
Also I have some json structure where values are not string in json.
Json example:
{“Message”:“124”, “data”:{“MT”:“msgtype”, “Qty”:23}}
{“Message”:“124”, “Data”:123}
Unable to set fields for this message.
I have tired to select_jsonpath and parse_json.
Kindly let me know how can I write pipeline for these example.
Try to use this pipeline rule, it should extract also inner json:
rule "extract-json"
    starts_with(to_string($message.message), "{") && ends_with(to_string($message.message), "}")
    let json = parse_json(to_string($message.message));
    let map = to_map(json);
    set_fields(map);
I had tired to use the above example but did not get the correct output.
Can I get the parameter Message, MT and UID as set fields with the above rule you have shared.
Json example:
If I undestand corretly, do you want field names MT, UID? Because my example extract its as data_MT, data_UID.
Check screenshot, how my snippet parsed your data.
json-extract
Thanks I will try data_MT should also be fine
I have attached the image for the pipeline and data.
I am getting the same data and fields are not set :
Kindly let me know if I have entered anything incorrectly.
You used non standard quotes “ not ", so pipeline rule doesn’t match at all. Change to normal double quotes, don’t copy and paste from this websites, as it’s changing it to non standard.
Thanks you for the update.
Even if I dnt copy and paste it. I dnt get the desired output.
I am unable to data_MT and data_UID
20200424_210635
Kindly help me with the solution.
I am still unable to get the inner json data.
I tried it on version graylog 3.2.4, with only one pipeline. Check if you don’t have pipeline, or extactors, that override json parsing.
I am using the same graylog version.
Using this pipeline I get message and data fields but unable to get the fields data_UID and data_MT as seen in your image.
Can you share your pipeline details and if any modifications done by you in json parsing.
Sorry for error, but i found that actual json inner extraction was done using json extractor, and not pipeline rule at all. I used this extractor on Input for json:
  "extractors": [
      "title": "json",
      "extractor_type": "json",
      "converters": [],
      "order": 0,
      "cursor_strategy": "copy",
      "source_field": "message",
      "target_field": "",
      "extractor_config": {
        "flatten": false,
        "list_separator": ", ",
        "kv_separator": ":",
        "key_prefix": "",
        "key_separator": "_",
        "replace_key_whitespace": false,
        "key_whitespace_replacement": "_"
      "condition_type": "none",
      "condition_value": ""
  "version": "3.2.4"
Thank you for sharing the details.
Can this be done using pipeline rules?
Maybe this could work for you, if you want parse only data {} content:
rule "extract-json2"
    let ex = regex(pattern: "\"data\":(\\{.*?\\})", value: to_string($message.message));
    let json = parse_json(to_string(ex["0"]));
    set_fields(to_map(json));
I want all the fields from the json including the inner json which I am unable to get.
I have a log line the following format:
“Details”:“request”,
“Other”:{
“MT”:“123”,
“St”: 2,
“Ip”:“192.168.0.9”
I have applied select_jsonpath to set field from json.
I need to use lookup table to get some values like parameter mt value 123 i need to replace from lookup to user1 and IP value to host name.
I want to use select_jsonpath to pipeline json fields.kindly help with the solution to implement lookup along with select_jsonpath.
Can you please help. If you need any other information let me know
Basically my issue is I have unable to read the inner json data on pipeline because of which lookup is not working
