Json nested and lsit
I try to format my json log, but so far without success.
My goal is to be able to parse the nested field like :
httpRequest, ruleListGroup
My current setup is quite easy, I defined a JSON extractor for an raw-tcp input.
And then I tried to create a pipeline with a rule.
Any help to understand what I do wrong is appreciated .
Hi, flep
please check syntax
In the rule, use the “parse_json” function to parse the nested fields. Here’s an example rule:
rule "Parse Nested Fields"
    has_field("message")
    let json_message = parse_json(to_string($message.message));
    let http_request = json_message.httpRequest;
    let rule_list_group = json_message.ruleListGroup;
    set_field("httpRequest", http_request);
    set_field("ruleListGroup", rule_list_group);
This pipeline rule attempts to parse the JSON in the message field and extract the httpRequest and ruleListGroup values into separate fields. Now you need to adjust the rule as needed based on your actual JSON structure.
Remember to check the Graylog server and processing pipeline simulator logs for any errors or warnings if things aren’t working as expected.
Hello bahram,
Thank you for your reply.
I tried multiple times with different codes, and the simulator showed me the same.
The server.log returns no errors too (I’m using docker) but it does if I make a mistake.
I appreciate your first help :slight_smile:
The sample I used to test the simulator:
    "timestamp": 1698624183281,
    "formatVersion": 1,
    "webaclId": "arn:aws:xxxxxxxxxx77a",
    "terminatingRuleId": "Default_Action",
    "terminatingRuleType": "REGULAR",
    "action": "ALLOW",
    "terminatingRuleMatchDetails": [],
    "httpSourceName": "ALB",
    "httpSourceId": "xxxxxxxxxx",
    "ruleGroupList": [
            "ruleGroupId": "xxxxxxx",
            "terminatingRule": null,
            "nonTerminatingMatchingRules": [],
            "excludedRules": null,
            "customerConfig": null
            "ruleGroupId": "xxxxxxxx",
    "rateBasedRuleList": [
            "rateBasedRuleId": "xxxxxx",
            "rateBasedRuleName": "xxxxxx",
            "limitKey": "IP",
            "maxRateAllowed": 998,
            "limitValue": "xxxxxx"
    "requestHeadersInserted": null,
    "responseCodeSent": null,
    "httpRequest": {
        "clientIp": "xxxxx",
        "country": "US",
        "headers": [
                "name": "content-length",
                "value": "1503"
                "name": "sec-ch-ua",
                "value": "\"Chromium\";v=\"118\", \"Google Chrome\";v=\"118\", \"Not=A?Brand\";v=\"99\""
                "name": "sec-ch-ua-platform",
                "value": "\"Windows\""
                "name": "sec-ch-ua-mobile",
                "value": "?0"
                "name": "user-agent",
                "value": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36"
                "name": "content-type",
                "value": "application/x-www-form-urlencoded"
                "name": "accept",
                "value": "*/*"
                "name": "sec-fetch-site",
                "value": "cross-site"
                "name": "sec-fetch-mode",
                "value": "cors"
                "name": "sec-fetch-dest",
                "value": "empty"
                "name": "accept-encoding",
                "value": "gzip, deflate, br"
                "name": "accept-language",
                "value": "en-US,en;q=0.9"
        "uri": "/track",
        "args": "",
        "httpVersion": "HTTP/2.0",
        "httpMethod": "POST",
        "requestId": "1-653ef2b7-xxxxx"
    "requestBodySize": 1503,
    "requestBodySizeInspectedByWAF": 1503,
    "ja3Fingerprint": "xxxxxx"
