Unable to see stracktrace in Graylog
I am new to graylog. I have created a Java Spring boot application. I have used de.siegmar.logbackgelf.GelfUdpAppender . In the Console , i am able to see the stack trace. But, in graylog, i am unable to see stacktrace. Any settings needs to be enabled on Graylog?
Below is my logback-spring.xml
<configuration>
  <property name="port" value="12201" />
  <property name="host" value="127.0.0.1" />
  <appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
    <encoder>
      <pattern>%green(%date) %highlight(%-5level) %yellow([%file:%line]) %blue(: %msg%n)</pattern>
      <charset>UTF-8</charset>
    </encoder>
  </appender>
  <appender name="GELF" class="de.siegmar.logbackgelf.GelfUdpAppender">
    <graylogHost>${host}</graylogHost>
    <graylogPort>${port}</graylogPort>
    <maxChunkSize>508</maxChunkSize>
    <useCompression>true</useCompression>
    <encoder class="de.siegmar.logbackgelf.GelfEncoder">
      <originHost>${host}</originHost>
      <includeRawMessage>false</includeRawMessage>
      <includeMarker>true</includeMarker>
      <includeMdcData>true</includeMdcData>
      <includeCallerData>true</includeCallerData>
      <includeRootCauseData>true</includeRootCauseData>
      <includeLevelName>true</includeLevelName>
      <fullPatternLayout class="ch.qos.logback.classic.PatternLayout">
        <pattern>%m%n</pattern>
      </fullPatternLayout>
      <staticField>app_name:graylog-spring</staticField>
    </encoder>
  </appender>
  <root level="DEBUG">
    <appender-ref ref="STDOUT" />
    <appender-ref ref="GELF" />
  </root>
</configuration>
Stacktrace in Console
2022-07-17 14:06:49,307 DEBUG [FrameworkServlet.java:1101] : Failed to complete request: java.lang.NullPointerException: Cannot invoke "String.length()" because "s" is null
Jul 17, 2022 2:06:49 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [dispatcherServlet] in context with path [] threw exception [Request processing failed; nested exception is java.lang.NullPointerException: Cannot invoke "String.length()" because "s" is null] with root cause
        at com.dagli.graylog.controller.Controller.helloerr(Controller.java:31)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.base/java.lang.reflect.Method.invoke(Unknown Source)
        at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
        at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:150)
        at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:117)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:808)
        at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1067)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:963)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:655)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
        at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100)
        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
        at org.springframework.web.filter.FormContentFilter.doFilterInternal(FormContentFilter.java:93)
        at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:540)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:357)
        at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:382)
        at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
        at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:895)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1722)
        at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.base/java.lang.Thread.run(Unknown Source)
2022-07-17 14:06:49,317 DEBUG [LogFormatUtils.java:107] : "ERROR" dispatch for GET "/error", parameters={}
2022-07-17 14:06:49,319 DEBUG [AbstractHandlerMapping.java:522] : Mapped to org.springframework.boot.autoconfigure.web.servlet.error.BasicErrorController#errorHtml(HttpServletRequest, HttpServletResponse)```
**Screenshot from Graylog**
![graylog|690x172](upload://hesvHijuLn8dPRrAxEmmtpsx7fu.png)
Looking forward for community support.
Thanks.
Can you be more descriptive?
Are you look for where the logs are in Graylog?
What kind on installation is this?
Hello @gsmith
I am running Graylog using the below docker compose. I am using the Java Spring boot Application with the logback GelfUdpAppender . On Graylog, i am able to see the log messages. But the stacktrace is not coming in the gray log.
docker-compose.yml
services:
  # MongoDB:
  mongodb:
    image: mongo:3
    volumes:
      - mongo_data:/data/db
  # Elasticsearch:
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.20
    volumes:
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
    ports:
     - 9200:9200
  # Graylog:
  graylog:
    image: graylog/graylog:4.2
    volumes:
    environment:
      - GRAYLOG_PASSWORD_SECRET=daglisecret12345
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
      - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
    links:
      - mongodb:mongo
      - elasticsearch
    depends_on:
      - mongodb
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      - 12202:12202
      # Syslog UDP
      - 1514:1514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
# Volumes for persisting data
volumes:
  mongo_data:
    driver: local
  es_data:
    driver: local
  graylog_journal:
    driver: local
logback-spring.xml
<configuration>
    <encoder>
    </encoder>
  </appender>
    </encoder>
  </appender>
  </root>
</configuration>
Refer to stack trace above …
My expected result is that even Java stack traces should come to Graylog.
Ok,
root  # docker logs -f <container_id>
Those are the logs but not in Graylog log file?
If this is correct perhaps something like this…
 graylog:
    image: graylog/graylog-enterprise:4.3-jre11
    network_mode: bridge
    dns:
      -  8.8.8.8
      -  8.8.4.4
    volumes:
       - graylog_bin:/usr/share/graylog/bin
       - graylog_data:/usr/share/graylog/data/config
       - graylog_log:/usr/share/graylog/data/log
Perhaps the graylog_log: environment setting will help.
