Unable to reach remote data node - Looking for basic auth?
Unable to add second data node to cluster. Was available during in-place migration, however shows unavailable after final graylog server restart. Logs show an error regarding basic auth, almost like the jwt is not being used
  • OS Information:
    Graylog/mongodb - Ubuntu 24.04.1
    Working data node - Ubuntu 24.04.1
    Failing data note - RHEL 8.1
  • Package Version:
    6.2.3+b5538f9
    [2025-06-04T17:03:23,861][INFO ][o.o.m.c.MLCommonsClusterManagerEventListener] [opensearch.ncg.local] Starting ML sync up job…
    [2025-06-04T17:03:27,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
    [2025-06-04T17:03:33,874][INFO ][o.o.m.c.MLSyncUpCron ] [opensearch.ncg.local] ML configuration already initialized, no action needed
    [2025-06-04T17:03:37,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
    [2025-06-04T17:03:47,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
    [2025-06-04T17:03:57,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
    [2025-06-04T17:04:07,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
    [2025-06-04T17:04:13,828][INFO ][o.o.i.i.ManagedIndexCoordinator] [opensearch.ncg.local] Performing move cluster state metadata.
    [2025-06-04T17:04:13,829][INFO ][o.o.i.i.MetadataService ] [opensearch.ncg.local] ISM config index not exist, so we cancel the metadata migration job.
    [2025-06-04T17:04:17,774][WARN ][o.o.s.h.HTTPBasicAuthenticator] [opensearch.ncg.local] No ‘Basic Authorization’ header, send 401 and ‘WWW-Authenticate Basic’
Verified setup with working data node, system reboots, service resets
Does anyone have a suggestion as to why its looking for basic auth? I followed the migration guide
