Unable to perform search query Index
Error Message:
Unable to perform search query Index not found for query: graylog_25. Try recalculating your index ranges.
Details:
  • Index not found for query: graylog_25. Try recalculating your index ranges.
Search status code:
500
Search response:
cannot GET http://:9000/api/search/universal/relative?query=%2A&range=300&limit=150&sort=timestamp%3Adesc (500)
What I did?
I manually deleted the indices in elasticsearch data location(filesystem).
Why I did?
I was facing some space issue and the graylog webpage wasn’t responding.
After clearing some 2Gigs of diskspace graylog was responsive. I deleted the indices in system>indices>default indes set>maintenance.
Please help me out to arrrive at a solution
did you recalculate the index range?
yes, I did. I found an option to recalculate the index in maintenance but it was in vain.
Even, I checked for the messages after bouncing graylog server.
Do I need to alter mongodb? If so, how? I have very limited knowledge in mongo
Did you check your Graylog server.log or Elasticsaerch logfile for errors?
