Lately I have been getting this WARN very often, is it something normal?
2019-06-05 17:19:00,634 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://apps.dev.ca/graylog/api/system/jobs on node <c3201551-f5d9-41c4-8b89-20b4c843c2ca>
at okio.Okio$4.newTimeoutException(Okio.java:232) ~[graylog.jar:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:285) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:355) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:227) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readHeaderLine(Http1Codec.java:215) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:88) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_192]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_192]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_192]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_192]
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_192]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_192]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:1.8.0_192]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:1.8.0_192]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) ~[?:1.8.0_192]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:933) ~[?:1.8.0_192]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:1.8.0_192]
at okio.Okio$2.read(Okio.java:140) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
... 28 more
When connecting to the url https://apps.dev.ca/graylog/api/system/jobs using curl:
[root@log1 graylog]# curl -v https://apps.dev.ca/graylog/api/system/jobs
* About to connect() to apps.dev.ca port 443 (#0)
* Trying 40.85.226.67...
* Connected to apps.dev.ca (40.85.226.67) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* Server certificate:
* subject: CN=*.dev.ca
* start date: May 08 22:49:50 2019 GMT
* expire date: Aug 06 22:49:50 2019 GMT
* common name: *.dev.ca
* issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
* NSS error -8179 (SEC_ERROR_UNKNOWN_ISSUER)
* Peer's Certificate issuer is not recognized.
* Closing connection 0
curl: (60) Peer's Certificate issuer is not recognized.
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
Then I proceeded to import the certificates in cacerts as follows:
wget "https://letsencrypt.org/certs/letsencryptauthorityx3.pem.txt" --output-document=letsencryptauthorityx3.pem
openssl x509 -outform der -in letsencryptauthorityx3.pem -out letsencryptauthorityx3.der
[root@log1 certs]# keytool -import -alias letsencryptauthorityx3 -keystore cacerts -file letsencryptauthorityx3.der
openssl x509 -outform der -in trustid-x3-root.pem -out trustid-x3-root.der
keytool -import -alias trustid-x3-root -keystore cacerts -file trustid-x3-root.der
However, I continue getting the WARN message. Do you know what else would cause this problem? I have been digging the logs in Graylog because I have problems in getting messages of the logs in Graylog. Filebeat is shipping the logs, but Graylog is not displaying them when searching in the UI and just this Warning message I am getting in server.log.
Thanks for your help
