I configured port 514 with authbind. I do see messages coming in but for some reason they get rejected. Any insights ?
netstat -tulpn
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN -
tcp 0 0 192.168.1.241:12900 0.0.0.0:* LISTEN -
tcp 0 0 192.168.1.241:9000 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:110 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 ::1:5432 :::* LISTEN -
tcp6 0 0 :::110 :::* LISTEN -
tcp6 0 0 :::143 :::* LISTEN -
tcp6 0 0 127.0.0.1:9200 :::* LISTEN -
tcp6 0 0 ::1:9200 :::* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 127.0.0.1:9300 :::* LISTEN -
tcp6 0 0 ::1:9300 :::* LISTEN -
udp 0 0 0.0.0.0:514 0.0.0.0:* -
udp 0 0 0.0.0.0:5514 0.0.0.0:* -
udp 0 0 0.0.0.0:2055 0.0.0.0:* -
udp 0 0 0.0.0.0:3514 0.0.0.0:* -
udp 0 0 0.0.0.0:68 0.0.0.0:* -
hkj@GrayLog:/etc/authbind/byport$
hkj@GrayLog:/etc/authbind/byport$ sudo tcpdump host 192.168.1.247
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ens18, link-type EN10MB (Ethernet), capture size 262144 bytes
20:08:07.733621 ARP, Request who-has 192.168.1.247 tell GrayLog.cybridllc.com, length 28
20:08:07.765808 ARP, Reply 192.168.1.247 is-at 00:15:60:eb:2a:40 (oui Unknown), length 46
20:08:08.024208 IP 192.168.1.247.syslog > GrayLog.cybridllc.com.syslog: SYSLOG user.debug, length: 77
20:08:08.024267 IP GrayLog.cybridllc.com > 192.168.1.247: ICMP GrayLog.cybridllc.com udp port syslog unreachable, length 113
20:08:08.024504 IP 192.168.1.247.syslog > GrayLog.cybridllc.com.syslog: SYSLOG user.debug, length: 67
20:08:08.024521 IP GrayLog.cybridllc.com > 192.168.1.247: ICMP GrayLog.cybridllc.com udp port syslog unreachable, length 103
20:08:08.026191 IP 192.168.1.247.syslog > GrayLog.cybridllc.com.syslog: SYSLOG user.debug, length: 77
20:08:08.026213 IP GrayLog.cybridllc.com > 192.168.1.247: ICMP GrayLog.cybridllc.com udp port syslog unreachable, length 113
20:08:08.026666 IP 192.168.1.247.syslog > GrayLog.cybridllc.com.syslog: SYSLOG user.debug, length: 67
20:08:08.761589 IP 192.168.1.247.syslog > GrayLog.cybridllc.com.syslog: SYSLOG user.debug, length: 79
20:08:08.761670 IP GrayLog.cybridllc.com > 192.168.1.247: ICMP GrayLog.cybridllc.com udp port syslog unreachable, length 115
