I’m trying to get Graylog to receive logs from my pfSense box. However, whenever I start the input I get the following error:
Input 'pfSense' could not be started
Request to start input 'pfSense' failed. Check your Graylog logs for more information.
In my /var/log/graylog-server/server.log I only have this warning constantly repeating itself:
15d23h25m25s│/var/log/graylog-server/server.log│2022-01-06T22:05:31.199+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m25s│/var/log/graylog-server/server.log│2022-01-06T22:05:31.207+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m27s│/var/log/graylog-server/server.log│2022-01-06T22:05:33.199+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m27s│/var/log/graylog-server/server.log│2022-01-06T22:05:33.210+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m29s│/var/log/graylog-server/server.log│2022-01-06T22:05:35.233+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m29s│/var/log/graylog-server/server.log│2022-01-06T22:05:35.244+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m31s│/var/log/graylog-server/server.log│2022-01-06T22:05:37.243+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m31s│/var/log/graylog-server/server.log│2022-01-06T22:05:37.254+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m33s│/var/log/graylog-server/server.log│2022-01-06T22:05:39.256+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m33s│/var/log/graylog-server/server.log│2022-01-06T22:05:39.268+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m35s│/var/log/graylog-server/server.log│2022-01-06T22:05:41.276+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m35s│/var/log/graylog-server/server.log│2022-01-06T22:05:41.296+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m37s│/var/log/graylog-server/server.log│2022-01-06T22:05:43.287+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m37s│/var/log/graylog-server/server.log│2022-01-06T22:05:43.313+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m39s│/var/log/graylog-server/server.log│2022-01-06T22:05:45.299+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m39s│/var/log/graylog-server/server.log│2022-01-06T22:05:45.310+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m41s│/var/log/graylog-server/server.log│2022-01-06T22:05:47.325+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m41s│/var/log/graylog-server/server.log│2022-01-06T22:05:47.336+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m43s│/var/log/graylog-server/server.log│2022-01-06T22:05:49.337+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m43s│/var/log/graylog-server/server.log│2022-01-06T22:05:49.346+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
15d23h25m45s│/var/log/graylog-server/server.log│2022-01-06T22:05:51.346+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/metrics/multipl│
15d23h25m45s│/var/log/graylog-server/server.log│2022-01-06T22:05:51.358+01:00 WARN [ProxiedResource] Unable to call https://192.168.20.27:9000/api/system/inputstates on │
I can’t any error message only the [ProxiedResource] warning.
I’m running Graylog 4.2.5+59802bf on logserver.mydomain.com / 192.168.20.27
Debian 11.0.13 on Linux 5.10.0-10-amd64.
My Graylog server is running behind HAProxy (on my pfSense) to provide a SSL Let’s certificate. When visiting the web interface it is correctly SSL verified.
Here is the uncommented lines of my server.conf file:
is_master = true
password_secret = some-secret
root_password_sha2 = some-text
root_timezone = Europe/Copenhagen
http_bind_address = 192.168.20.27:9000
http_enable_tls = true
http_tls_cert_file = /etc/ssl/graylog/graylog-cert.pem
http_tls_key_file = /etc/ssl/graylog/graylog-key.pem
http_tls_key_password = my_password
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
I have searched online but without any help. I don’t know how to debug so any help is highly appreciated.
