Total messages processed per node
I am trying to create a template in Zabbix to monitor some aspects of Graylog. One of them is the total number of messages processes per node, but I can’t find in the API any endpoint with this information. Is this available anywhere?
Thanks.
Depending on what you exactly want to monitor, you can use these metrics (see /system/metrics in the Graylog REST API):
  • org.graylog2.shared.buffers.InputBufferImpl.incomingMessages
  • org.graylog2.shared.buffers.ProcessBuffer.incomingMessages
  • org.graylog2.shared.buffers.processors.ProcessBufferProcessor.incomingMessages
  • org.graylog2.shared.buffers.processors.ProcessBufferProcessor.outgoingMessages
  • org.graylog2.buffers.processors.OutputBufferProcessor.incomingMessages
  • org.graylog2.buffers.OutputBuffer.incomingMessages
Thanks @jochen, which is the metric most suitable metric to get the number of all messages received, from any input, before any filter, grok, pipeline, etc.?
That would be the first one: org.graylog2.shared.buffers.InputBufferImpl.incomingMessages
Just if anybody wants, I have created a Gist with info about monitoring Graylog (journal and number of processed messages) with Zabbix.
It would be great if you could move this to a “real” GitHub repository and add it to the Graylog Marketplace. :slight_smile:
:arrow_right: http://docs.graylog.org/en/2.3/pages/marketplace.html
