Get alerts when unprocessed messages reaches limit
Newbie here. We’ve been having issues with Graylog going down in some deployments since it was getting too many logs, we solved it (hopefully) by increasing the JVM heap size for both Graylog and Elasticsearch (4G each).
We where at 963,141 unprocessed messages when it went down.
Now we want to set up some kind of alert that can tells us when there are too many unprocessed messages (we have all the infrastructure on AWS) so we can get alerts when Graylog is stuck on those processes since we are not able to know unless we manually check the server.
This is our server.conf
is_master = true
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Thanks!
check this Monitoring :
if you are looking high-volume process, look out for Graylog sizing.
Hello && welcome @richiexlinares
Adding on to @ramindia suggestion.
Using the Metrics on Graylog node works…
Found here.
what I did was enable Prometheus in Graylog config file the Install Grafana. This gave me the ablility to send an alert if something went wrong.
Example:
This also can be done through Zabbix.
Unprocessed message, I belive that would be the Journal.
Example:
